How To: Find your Vehicle's VSS Wire.
By JasonH · Oct 24, 2005in Vehicle Specific Wiring💬 346 posts👁️ 199,818 views
Page 2 of 14
Posted Oct 30, 2006 · 01:38 UTC#26
I am going to guess based on previous experience, that yes they retalking about the one under the driver side dash.
Posted Nov 06, 2006 · 01:59 UTC#27
Hi. Hope you had a nice weekend. I spent the entire weekend installing the Z1. I'm completely bushed! Mostly a success, but some issues arose. Perhaps you can help? Questions:
1) Reverse Signal: There's only one 9-pin connector on the back of the fuse box (under dash driver's side), but pin '5' is empty (both male & female sides). Could it be one of the other pins (I attached a photo of the 9-pin connector - counting from lower right going left, pin 4,5,6,7,8, etc.)
2) Can you tell me where I can easily (i.e., under dash, near fuse box??) tap into BATTERY?
3) I get an emphatic "oomph" sound through the speakers when I turn the car off (even after turning off the unit (as much as it can be turned off, that is)). All sounds fine while it's playing; I checked left, right, front, rear settings, and all seems well; I'm getting highs through my tweeters and bass through my woofer. Any ideas what could be wrong? I'm certain I made good grounds; help......
Posted Nov 07, 2006 · 02:01 UTC#28
That looks to me like a 10 pin plug. Kinda hard to tell for sure though your finger's in the way a bit. You could look in the harnes that runs to the back of the car on the driver's side for a white wire. That might work to.
what do you need to tap into a batteryfeed?
The pop/thump noise you're hearing is normally caused by the factory amp turning off too soon. What you can trry doing is disconnecting the blue/white wire of the car's harness from the z1 and splice it into the red wire. If that doesn't work, you'll need something to delay the turn off of the amp.
Posted Nov 08, 2006 · 08:05 UTC#29
THERE ARE 2 WIRES LEFT LOCATED IN THE STOCK WIRE HARNESS. (WHITE) AND (WHITE/ORANGE). ARE EITHER OF THESE MY VSS WIRE? AND IM LOOKING FOR MY ILL. WIRE AS WELL.
Posted Nov 08, 2006 · 14:20 UTC#30
Turn off the caps lock. And a year make and model would be helpful
Posted Nov 08, 2006 · 21:52 UTC#31
Sorry about that. I have a 06' Mitsubishi Raider.
Posted Nov 08, 2006 · 23:45 UTC#32
2006 mitsubishi raider.
Try this
Speed Sense DARK GREEN/WHITE AT ABS MODULE ON DRIVERS SIDE OF FIREWALL UNDER HOOD
PIN #27
merry xmas
Posted Nov 09, 2006 · 00:13 UTC#33
Thanks, i will give it a try. Do you know what the (White) and the (Orange and White) wires are located on the stock stereo wire harness are?
Posted Nov 09, 2006 · 00:19 UTC#34
nope not a clue. never worked on one.
Posted Nov 09, 2006 · 04:35 UTC#35
well, no luck with the Pin #27.
Posted Nov 09, 2006 · 07:57 UTC#36
:shock:
2005 Jeep Liberty Renegade Auto Tranny, NEW AVIC-N3 install, no factory Navi
I have done my research so I have a clue. The wonderful people at Rostra have provided me with a VSS wire location: "Automatic Trans. Location 15 (Driver's Side Fenderwell between shock tower & front grill) - 4 Connector ECM - Green Connector - Position 32, VSS Wire Color: Automatic Lt. Green/White or Green/Brown."
My problem is that I found two Green/White AND two Green/Brown in that specific connector. I do not know which to tap. And lastly, I am looking for a place to tap the reverse signal wire so I don't have to travel to my tail lamps!!
The connector on the right is the "Green." You can see the TWO Green/White and the Green/Brown next to it.
This is the green connector...its position 32.
Here you can see the TWO Green/Brown better.
Posted Nov 10, 2006 · 00:53 UTC#37
Here ya go
2005 Jeep Liberty
Reverse Light white/gray + driver kick, harness to rear
Speed Sense dk. green/yellow BCM, 26 pin plug, pin 20
Notes: The BCM (Body Control Module) is attached to the left of the fuse box.
That's what I have as far as the wiring info goes
Merry xmas
Posted Nov 10, 2006 · 06:23 UTC#38
Where is the BCM? There are two fuse boxes, the one in the engine bay and in the passenger compartment.
Merry xmas to you too!
Posted Nov 10, 2006 · 13:11 UTC#39
The one in the passenger compartment is when the bcm is.
Posted Dec 09, 2006 · 04:46 UTC#40
hey i have a 2006 gmc sierra with a duramax where do i find the vss wire and reverse wire thanks
Posted Dec 12, 2006 · 02:31 UTC#41
2006 GMC Sierra
Reverse Light lt. green + BCM, black plug, pin F
Notes: The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back.
Speed Sense dk. green/white 4K instrument cluster, pin A4 or PCM
Notes: The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud.
On gas models, the VSS wire is in the green plug, pin 50.
On diesel models, the VSS wire is in the black 58 pin plug, pin 42.
Also found at the radio harness, on some models.
merry xmas
Posted Dec 12, 2006 · 13:44 UTC#42
hey thanks cntry merry xmas to you to !
Posted Dec 12, 2006 · 13:45 UTC#43
Posted Dec 30, 2006 · 21:27 UTC#44
What sender should I get for a car that originally had a mechanical spedo sender so the Z1 will ba able to read the speed correctly?
The vehicle is a 1972 BMW 3.0CS.
Posted Jan 04, 2007 · 01:45 UTC#45
ND-PG1 is the speed pulse generator. From what I remember it straps onto the drive shaft of a rear-wheel drive car.
Posted Jan 19, 2007 · 00:24 UTC#46
How about a 2004 Nissan Sentra SE-R Spec v. Thanks
Posted Jan 19, 2007 · 02:23 UTC#47
2004 Nissan Sentra
Speed Sense red/yellow instrument cluster
merry xmas
Posted Jan 24, 2007 · 21:34 UTC#48
damn my car is not listed on here........ :(
Posted Jan 24, 2007 · 21:37 UTC#49
What kind of car, apax?
Posted Jan 24, 2007 · 21:39 UTC#50
mitsu 1999 3000GT
Page 2 of 14
