Do you think we will be able to " bypass " this system?
Bypass?
Nevar!
There will always be a bypass. It's just a matter how difficult it will be to find/do.
why would you want to,its illegal ![]()
I'm hoping that JasonH will have an answer on this soon. I'm going to be selling my D3 to upgrade, but not being able to bypass would likely stop me from selling.
It's not just the video (which aside from being illegal, is REALLY dumb to be watching while driving -> unsafe), but being able to change destination and/or other nav related stuff while driving.
Not everyone drives by themselves, and being able to have my girlfiriend do searches for stuff while I'm on the highway is def handy.
its also a great way to stay awake if your on a long drive. speeding is illegal too but every1 does that too, and how many people really wear their seatbelts? or drive while talkin on ur cell phone? just be responsible with it and you'll be fine
I for one, never bypassed my D3, and it was a royal pain in the ass. Even when stopped, I couldn't modify anything or type in addresses. It took so long for the system to finish booting up after starting my car, I could be 5 houses down the street by the time the system finally let me type anything. I finally learned to compensate by pulling up the parking break every time I was at a stop sign or a stop light. Quite annoying. And, if someone was the passenger in the car (which is most of the type since my husband & I share a car), it's down right silly to have to pull over and pull up the parking break just to look up where a nearby restaurant might be.
the d3 is a simple 2 wire bypass, deffinitly worth the 5 minutes installing it
Jason,
Are you going to attempt the bypass soon? My F90BT will be here next week and i'd like to avoid pulling my dash out after a permanent install...
Just recieved our first F700BT and installed it in my own car for inspection purposes. Very nice! Tried just grounding light green wire first and video shuts off when hitting around 10mph. then took the mute wire and moved it into the empty slot just above it on the end of the harness and grounded it. no luck and video shuts off the same. I'll keep trying other ways know and see if anything hits. good luck to us!
not to be a buzzkill, but a good portion of this forum is dedicated to finding ways to bypass pioneers units...im sure pioneer caught on and fixed the wire method for the F so it may be almost impossible to bypass it.
You're kidding yourself if you think they want to make them difficult to bypass...they wouldn't sell any like when the Z2 first came out. The wire method is perfect for them because it proves that the deck wasn't hooked up as was intended in the manual. Thats why they stuck with it for the D3/N4/and entire Z-series. I would bet that its still a wire that needs to be moved, will just take some experimenting to figure out which one
How many open holes in the RCA harness?
didnt think of it that way....valid point
Just throwing out ideas.
not sure if this is how it would even work or not.
but as for the parking brake. does the parking brake provide a low current voltage when engaged? if the AVIC brake line was something that could be hooked up to say, a remote line.? to trick the unit into thinking it's engaged? I'm guessing that if there was a computer signal for the brake being active. A. it would be different from car to car. B. the unit wouldn't know how to read it.
-> I re-read the previous post. interesting that it's shutting off after about 10mph. would it still do this with the GPS unplugged? and is the VSS line hooked up?
just trying to think of ways to trick it. fingers crossed that a solution can be found. I'd hate to have to hold onto my D3 because of this. I can't not have it bypassed. I need access to the nav features.
it'll get bypassed, just a matter of time....
Just throwing out ideas.not sure if this is how it would even work or not.
no vss wire on this unit. Uses GPS reception only.
I noticed that ad earlier today on ebay. claims he can bypass it. does need some spell/grammarcheck in his auction though lol
You are a BUZZKILL!!!!!!!!!! ![]()
hahahaha Ohwell im sure with time someone with find some type of program or wiring change which would override their design. Its all a matter of time. Trial and eror an famous philosopher once said. Especially with this new flash card and they way technology is, im sure there is some computer guru which will be able to figure it out.
haha, i also said i havent been following up with the F series cuz i think its overrated. but if you go back to whtcrxghst's reply, he gives a good point.
so ![]()
bak atcha!!
oh no you didn't. lol Well i think the D3's navigation sucked for the most part and the fact that the navigation disk were from 2006 and so many roads are under contruction in my area, the f-series is a nice choice. Plus it was a bi@tch pulling out the navigation DVD to watch a DVD or listen to a CD. But then again you aren't supposed to be watching movies while moving.Just recieved our first F700BT and installed it in my own car for inspection purposes. Very nice! Tried just grounding light green wire first and video shuts off when hitting around 10mph. then took the mute wire and moved it into the empty slot just above it on the end of the harness and grounded it. no luck and video shuts off the same. I'll keep trying other ways know and see if anything hits. good luck to us!
so
bak atcha!!
Is the bypass system the same in the European versions too? I'm living in Hungary. ![]()
Is there a final solution to bypass the system?
I PM'd the guy on eBay about the bypass and he says hes bypassed 3 of the new AVIC F series units with his method and each have worked flawlessly. If a few of you guys will pitch in I dont mind buying it and posting it on the site tonight, as I got mine in today. my paypal is [email protected], just some dollar or two donations would be nice. I understand im a new member but im pretty reputable on caraudio.com, same username. If you guys dont trust me we can do the same thing but have a more respected member do the same thing. just an idea.
It looks like we already have it posted. See thread below.
http://avic411.com/forum/posting.php?mode=reply&t=15349&sid=3cc92547543541867c37c05c16cea7ed
Way to copy the URL of you replying to this topic, man! ![]()
