I am doing this now....I am buying 70-8116 Metra harness as suggestd by Metra and bypassing the JBL amp. This harness has power wires which can directly connect to the JBL speakers ..No RCA connection involved here and this should solve the noise problem...... Though Metra suggested I buy a 5 channel amp and use it , I dont have any more money to spend for next 3-5 months on this...I will settle for this setup for now and in 6 months will upgrade if I am not happy..
This is the last email from an expert in Metra..
Replace the existing harness for a 70-8116. That is a amp bypass
harness for the factory system. I would go with a five channel amp and
have four channels power the highs, and a fifth for a sub that you will
install now, or later. The speakers you can possibly keep for a bit, but
you will want to change them soon.
Any good amp should have four gauge power wire inputs. If so, use
our AMP04BL amp power kit, along with V104-17 four channel rca, V10-17
two channel rca, and a X15WSW12-KT speaker wire kit for the subwoofer.
With the Pioneer radio giving you front, rear, and sub controls, you
should have total noise free control of the system, and you should be
very happy. I did not recommend any products as that is your decision.
You can e-mail me back and I will give you my unbiased opinion if you
like. Circuit City should have plenty of products to demo. If not, try
Crutchfield or Best Buy. Keep in mind that only Circuit City or
Crutchfield can special order products from us.
