Will the ipod shuffle work with my d3?? I did a search on it but didnt come up with anything
Thanks in advance
Thanks in advance
The ipod shuffle doesn't have the data port like the larger ipods do, so you can't hook it up using the Pioneer ipod cable and control it with the D3. You would have to run it's audio output to either of the AV inputs and use the actual ipod to control everything. And of course video playing isn't an issue, because the shuffle doesn't play video.
From Pioneer's website about the CD-I200 cable:
Directly connect an iPod® nano or iPod® to the headunit to control menus and songs on the iPod, including the lastest shuffle function, via the headunit interface. It's as quick and easy as manipulating the iPod itself. The cable is 2 meters (6.5') in length, and plugs into the Dock port on the bottom of an compatible iPod or iPod nano (3rd-, 4th- or 5th-generation iPod, iPod nano, iPod Video).
thanks for the info!!
