best buy installation try to bypass
By germanplazas555 · Jun 06, 2008in General💬 10 posts👁️ 1,327 views
Posted Jun 06, 2008 · 21:58 UTC#1
I got the installation from best buy .. but I want to bypass it and I dont Know wat to do. I know that u have 2 move the pin on the mute but I dont know what else .. thank u if u can help me
Posted Jun 06, 2008 · 22:12 UTC#2
Move the mute and ground the mute and parking brake wires. Disconnect the parking brake wire from it's current location prior to grounding it.
http://avic411.com/forum/viewtopic.php?t=4670
Posted Jun 06, 2008 · 22:40 UTC#3
how do i ground them... to where a metal part or what
Posted Jun 07, 2008 · 18:48 UTC#5
so let see if i got... so when i get my car i just need to swith the pins of the mute cable then groung the cable to a metal ... and then take the green cable and ground it also to a metal??
Posted Jun 07, 2008 · 19:42 UTC#7
what about is best buy didn't used yellow and black wires do i plug get in and then ground it.. or do i just leave it loke that and groung only the green cable and thats it...
Posted Jun 07, 2008 · 19:50 UTC#8
I'm afraid I don't understand what you're asking.
Posted Jun 07, 2008 · 19:53 UTC#9
i went and look behind the radio and i notice that they didnt use the white connetor that has the mute mire.. they just used the black connecter that has the green connecter... they left the white connecter in the box.. im asking if i just plug it in and than ground it .. or what...??
Posted Jun 08, 2008 · 00:14 UTC#10
You'll need to use the white connector. You need to relocate the yellow mute wire as shown in this post http://avic411.com/forum/viewtopic.php?t=4670 Once this has been done, ground the yellow mute wire. If The green parking brake wire is connected to the parking brake, you'll need to disconnect it, then ground it also.
