Hi everyone, I've searched this here and on another forum already. What exactly do i need to do the bypass. I've seen things like the DEI528T, TR-7, and just wiring diagrams. so what exactly do i need because i just got this installed at a local shop yesterday and the guy that installed it said it was grounded to work while i'm driving but it doesn't. it doesn't even play a dvd at all. when i put in the dvd, the audio would work but no video on the display.i'm going back to the shop tomorrow so can anyone help me out. thanks in advance
Pioneer AVH-P4000DVD bypass unit
I just ran the parking brake and the groung wire to a closed circuit switch. That way when I need the bypass all I do is push the switch and im set.
See this post - http://avic411.com/forum/viewtopic.php? ... vhp4000dvd
I did what saleengt2001 suggested and it works perfect!!!
I used this switch
And it only works if I keep my finger on the button so it's down. The switch doesn't click. Would a cheap toggle type of on/off swtich work?
I'm going to try to just ground the wires(I've read so much online for diff ways) and if that works, I don't need the switch...but if not...would a toggle or a switch that actually clicks work?
The one I have just pushes in and doesn't click into a position.
and connected the parking brake wire to the switch, then from switch to a ground...i will be able to watch video while driving?[/url]
both switches should work fine!
Use a toggle switch. I ended up returning the others and buying a nice chrome plated switch and it works perfect.
