Ok. From day one I've had alternator whine and this weird "static" interference. It's not speaker noise, since its not present when the car is on acc and the engine is not on, but it is when the engine IS on. Today I decided screw the factory ground and spliced the ground wire on the D3 and turned it into a 12-gauge and went straight to the negative terminal on the battery...no difference at all. The amplifiers, (two PDXS) and a matrix line driver, I re grounded on the chassis with the JL Master Lug (sanded down to be shiny metal, bolted on, then spray painted over to prevent rust) and I still have noise coming out of the speakers...the static interference really isn't a bad thing since you can't hear it UNLESS you put your ear up to the speaker, but the alternator whine is getting annoying, however it only does it when I go above 3k rpms (or full throttle it) and then you hear it wind down when I let off. Any ideas? D3 has a fantastic ground, as do the amplifiers.
The only other thing I could think of would be a blown RCA ground within the unit itself, but I've heard of horror stories of people grounding the rca shield to the D3 chasis and BLOWING the D3 rcas grounds since they really weren't blown.
What are your thoughts? I should add that almost all of the static interference goes away when I unplug the rcas from the line driver, then again that could just be because it's not getting "gained" but I dunno.
Do these double-din pioneer units just naturally put out this "noise?" My buddy has a D3 and has been having noise issues too..
