I have a firmware update!!
By hellodave · Jul 16, 2008in General💬 29 posts👁️ 12,665 views
Page 1 of 2
Posted Jul 16, 2008 · 15:10 UTC#1
I logged a call with Pioneer Customer Relations last week, and reported my problems with the F900. This morning, I received a package from them...inside was an SD card and some hastily typed instructions.
N.B. This is an update for a UK spec F900BT, so it may not apply to other models or regions...I don't know.
I ran the update at lunchtime, so haven't had much chance to play with it yet. The procedure is pretty simple - insert SD card, turn the unit on, and let it run. The update took about 10 minutes from start to finish. The old software version was 1.000.600 and the new one claims to be 1.001.500 (I think!).
Initial impressions (bearing in mind I've only had half an hour with it so far) -
- The update didn't screw the unit up...not yet anyway! :P
- USB playback is now fine in the map screen, with no stuttering.
- Bootup time may be slightly quicker, but not by much. I timed ~35 seconds to show the main menu (still with "system startup in progress" displayed), and about 55 seconds from switch on until the startup message has gone.
- The response when you touch a button may be slightly snappier in some places.
The only downside is the unit now seems to reset the "Master Volume" (under navi settings...sound settings) to full everytime it boots (twice so far), and it forgets whatever you change it back to. However, I haven't tested this much yet, and the unit hasn't been reset since the update, so I may be jumping the gun on this one.
I don't have an iplop so can't test that out, and bluetooth was fine for me before the update, so I can't say if it's improved (assuming it hasn't got worse - I haven't tried it yet!).
Posted Jul 16, 2008 · 15:19 UTC#2
interesting... :shock:
Posted Jul 16, 2008 · 15:43 UTC#3
So not only did they not significantly address the issues in the original firmware release, but they managed to introduce a new one?
We really need to get someone with an iPod and the firmware update to chime in.
Posted Jul 16, 2008 · 15:49 UTC#4
Possibly. Until I've tried resetting the unit and/or resetting the nav back to factory defaults, I wouldn't like to say for sure.
For example, what if the old firmware stored nav volume as a value between 1 and 100, and the new one stores it as a value between 1 and 20. If mine was set to 50 and then I upgraded, the unit could interpret that as max and not be able to change it back because it's an "illegal" value. It's a long shot, but you never know...
Posted Jul 16, 2008 · 15:54 UTC#5
Right, but if they made changes like that, the firmware itself should update that value to be in the correct range.
That's just sloppy coding if it doesn't.
Posted Jul 16, 2008 · 15:57 UTC#6
Quite right, or a least update the instructions to say "reset the unit after updating", but I am only guessing at possible causes. Most likely they've just screwed the coding up and no resets will fix that!! :P
My SD card had no Pioneer branding and the instructions were hastily typed on a sheet of A4, so this may not be the final update...who knows... :?:
Posted Jul 16, 2008 · 16:08 UTC#7
Yeah, I would be really surprised if the firmware didn't force a reset when it was done installing.
I really want to believe in this update, I'm just too much of a skeptic based on my prior experiences with Pioneer.
Posted Jul 16, 2008 · 16:14 UTC#8
I'm going to venture a guess and say that it's not the "final" release of the firmware update and is more of a trial or unofficial release or something like that... based on the fact that it was procured as a result of a call to customer service to complain about the various problems with the unit and the fact that they haven't actually released any info stating that they have released the patch for distribution.
Posted Jul 16, 2008 · 16:16 UTC#9
Even if they don't fix all or most of the problems, as long as they can easily allow us to patch our product, I am ok with it.
Most software houses rely on patches these days unfortunately. But, take a look at the Xbox360, the PS3, ipod, etc etc, they have all gotten better over time because of patches.
Pioneer just needs to show me that they are indeed focused on improving the system, and I am happy.
Posted Jul 16, 2008 · 19:33 UTC#10
I hope you're right - after a reset and some more testing, the master voice/"bong" volume still has a mind of its own, the unit still skips the last few seconds of USB tracks when it feels like it, and USB resume is still flaky.
Still, at least they've fixed something... :)
Posted Jul 16, 2008 · 19:34 UTC#11
Have you called back to tell them the update was ineffectual? They may interpret no feedback as good feedback...
Posted Jul 16, 2008 · 19:40 UTC#12
What exactly did they fix?
Posted Jul 16, 2008 · 21:22 UTC#13
Customer relations are supposed to be calling me back this week...we shall see.
USB no longer skips on the map screen :lol:
It may have fixed my "F900 won't start up when the temp is below 16C" issue as well, but I won't know that until tomorrow morning.
Posted Jul 16, 2008 · 21:38 UTC#14
LOL... you're the guinea pig for the patch.
Posted Jul 17, 2008 · 01:34 UTC#15
Be nice... :lol:
Posted Jul 17, 2008 · 02:09 UTC#16
He's the guinea pig? We're all guinea pigs beta testing this headunit heh. Thanks for the updates and keep us updated.
Posted Jul 17, 2008 · 05:04 UTC#17
I think calling us alpha testers is probably more accurate. This next wave of firmware that is being released is the beta test.
Posted Jul 17, 2008 · 05:12 UTC#18
Have you tried the nav yet with your "update" ? When in 2D mode, did the update give you the ability to switch from north up view to heading up view? That's the pretty much the one single problem I have with the nav portion of the unit.
Posted Jul 17, 2008 · 07:36 UTC#19
I'll try that next time I've got the nav on. Not holding out much hope though!
The unit failed to boot up again this morning, so the update hasn't fixed that either :roll:
Posted Jul 17, 2008 · 14:37 UTC#20
Hopefully there will be some folks out there who, after installing each rev, will systematically go down the bug list(s) and say point by point what's fixed and what's not
...rather than random posts talking about this or that function.
Posted Jul 17, 2008 · 15:04 UTC#21
as soon as a few people get their hands on the fw update,i guarentee therell be a before and after update thread to show ezactly what has changed and wat hasnt. jus hang tight
Posted Jul 17, 2008 · 21:21 UTC#22
Can you copy the data from the SD card to your computer and ZIP it up? I'd love to see some files on that card.
Posted Jul 17, 2008 · 22:15 UTC#23
I'm sure you can copy it to your computer and dig through it... it's just data on a storage device, nothing special.
Posted Jul 18, 2008 · 01:43 UTC#24
Big question is: Why can't Pioneer test this stuff themselves?
It doesn't take log to see that the unit is not working properly.
It is not like "well on certain instances, the unit takes 2 minutes to boot up"
Everything that you guys talk about is very obvious, almost in your face bugs. Yet they chose to release it anyway and have the nerve to keep you guys hanging this long for some sort of fix that doesn't really fix most of the problems.
If I had bought this unit, I would call Pioneer and demand a refund and then take my business elsewhere.
Sorry guys. I feel your pain. Think of all of the time you spent trying to figure out if the problems you are seeing are perhaps an oversight by you like you may feel that you are dong something wrong. It really makes me upset that you guys spent big bucks on this thing and are left with a half ass unit. And it is not like it is easy to return because you may ave altered your car to install it and it may not be so easy to remove so you may have to pay someone to take it out and put your car back the way it was.
Sorry guys. I am cranky tonight.
Posted Jul 18, 2008 · 01:48 UTC#25
...Sorry guys. I am cranky tonight.
You've come to the right place
Page 1 of 2
