nav arrow side ways
By jtbmoore · Jul 17, 2008in General💬 26 posts👁️ 3,333 views
Page 1 of 2
Posted Jul 17, 2008 · 17:04 UTC#1
I just got my avic installed and the nav arrow is side ways as I drive. I have tried the compass and it is still off. If I change the view to street view it shows side ways as well. Anyone seen this.
Posted Jul 17, 2008 · 17:05 UTC#2
FYI, I did the motion hack. I don't know if this matters.
Posted Jul 17, 2008 · 17:11 UTC#3
Is this a new unit or a used unit? Also, check your satellite signal and see how strong it is.
Posted Jul 17, 2008 · 17:15 UTC#4
new, and its strong
Posted Jul 17, 2008 · 17:17 UTC#5
are you sure you pressed the red/white compass while on map view?
Posted Jul 17, 2008 · 17:20 UTC#6
Yeah, it changes but the arrow is still pointing the wrong way.
Posted Jul 17, 2008 · 17:25 UTC#7
How much have you driven it since you installed it? Sometimes it takes a few days worth of driving for the nav to figure out where it is and get accustomed to the car.
Posted Jul 17, 2008 · 17:39 UTC#8
Not much, I will monitor over the next week.
Posted Jul 17, 2008 · 17:51 UTC#9
mine did the same thing... is you VSS wire hooked up? If not, it will be sideways like that.
Posted Jul 17, 2008 · 17:52 UTC#10
I assume the vss wire is hooked up. Isn't that part of the motion hack? I am drawing a blank on the VSS wire for some reason.
Posted Jul 17, 2008 · 19:30 UTC#11
the speed sense wire, i believe its the pink one.
Posted Jul 17, 2008 · 21:59 UTC#12
No, the VSS wire doesn't have anything to do with the bypass.
Posted Jul 17, 2008 · 22:01 UTC#13
What do you connect the vss wire to. Maybe I missed this one.
Posted Jul 17, 2008 · 22:25 UTC#14
You connect it to your vehicle's speed sensor wire.
To check if it's hooked up, go to the 3D calibration screen in the nav settings menu and if you drive the car, the number next to speed signal will go up with your speed.
Or another method, go to the nav map, hit the map button again, and select vehicle dynamics. A screen with some dials will pop up, the center one being a speedometer. It will show your speed if the VSS wire is hooked up. If the wire isn't hooked up, it will not register your speed and stay at zero.
You might want to try both methods, as I can't quite remember if the speedometer gauge also uses the GPS signal to get the speed reading.
Posted Jul 18, 2008 · 13:08 UTC#15
If you find that it is not working after you perform those tests, take it back to the place you got it installed and make them finish the job.
Posted Jul 19, 2008 · 22:19 UTC#16
thats the problem your vss wire is not hooked up correctly.
Posted Jul 21, 2008 · 15:39 UTC#17
It is not getting better. Maybe I forgot to hook up the VSS wire. What does that connect to?
Posted Jul 21, 2008 · 15:53 UTC#18
The wire depends on the car. What type of car do you have?
The VSS wire is the Vehicle Speed Sensor wire. It connects to the wire going into your dash where the spedo gets the signal it uses to display your speed.
Posted Jul 21, 2008 · 16:36 UTC#19
I drive a 2008 Toyota Tundra.
Posted Jul 23, 2008 · 19:42 UTC#20
Does anyone know where the vss connects to for a 2008 Toyota Tundra?
Posted Jul 24, 2008 · 21:16 UTC#21
Have you tried doing a reset on the calibration and maybe on the unit....??
I ran with my VSS unhooked for a while and had no issues
Posted Jul 25, 2008 · 06:00 UTC#22
The speedometer on the map works off of the GPS because I don't have my VSS wire hooked up and the speedo does work. I don't have any issues with which way my arrow points though.
Posted Jul 28, 2008 · 22:46 UTC#23
How do I reset the calibration?
Posted Jul 29, 2008 · 01:33 UTC#24
At the menu that shows your calibration mode of simple hybrid or 3d hybrid.... there is a clear button next to it to press....
Posted Jul 30, 2008 · 13:03 UTC#25
I do not have the VSS hooked up and have no issues with the arrow, nor the Pioneer gauges working. As was said, try resetting.
Page 1 of 2
