F900BT install vs D3
By mcynet · Aug 02, 2008in Hacks/Mods💬 6 posts👁️ 3,077 views
Posted Aug 02, 2008 · 21:38 UTC#1
I currently have a d3 can I just unplug the d3 an plug in the F900bt?
I just ordered the F900BT It should be here this week, I just wanted to know what need to do the install. It looked like online the wiring is the same except on the bypass,
I just need to move the mute wire I have grounded now in between the 2 ground wires.
Is this correct or is there more I need to know?
Posted Aug 03, 2008 · 09:48 UTC#3
Connector on the GPS antenna is different 2
Posted Aug 03, 2008 · 14:48 UTC#4
i was surprised to find the wiring harnesses the same but it made everything so easy and the mute wire mod was easy to. I purchased my unit and installed it in the parking lot lol. just my antenna wire was a real pain to get to
Posted Aug 05, 2008 · 02:37 UTC#5
I just installed w/ bypass works great
The GPS was diffrent Itook a small screwdriver and pulled the tabs up on the d3 plug and removed it then did the same to the new gps plug I swaped the ends and it works great.
Thanks All
Posted Aug 05, 2008 · 03:57 UTC#6
Yep. Like he said... the GPS antenna and cable are exactly the same for both units aside from the plastic connector on the end... all you have to do is swap out the small plastic connector/plug on the end of the D3's antenna cable and it will work with the F-series unit.
