AVIC-F900BT european version ( Slow bootup Solution ???? )
By rufisa · Aug 08, 2008in Problems/Troubleshooting💬 18 posts👁️ 5,253 views
Posted Aug 08, 2008 · 20:42 UTC#1
Hi all
I'm from portugal and I've just bougth a brand new avic-f900bt, but I fell bad about portugal pioneer electronics, they don't have much information about this new unit, and the problems they already have, I think I will be desapoited if pioneer dosen't put the corrections for this firmware soon
1st the unit as no voice command like the american model I'm afraid we are 2nd class people
2nd every time you turn you car key on, does you unit spend so mutch time for botup (more or less 1 minute), or there is another way to listen music while the unit are doing all the check ?
because this waiting time is boring.
Posted Aug 08, 2008 · 20:46 UTC#2
Nope... none of the European F-series models have the voice command feature. I don't know why they chose to put it into the US units and not the Euro units. Kinda shitty if you ask me.
And the 1 minute boot up time is "normal"... everyone's units do it. As of right now Pioneer's official work is that it is supposed to operate that way. So my guess is they have no plans to alleviate it in the foreseeable future.
Posted Aug 08, 2008 · 21:19 UTC#3
Ok too bad
and do you know how other's systems work ? like alpine, kennwood, clarion, will they do the same slow start ?
Because I didn´t install the system in the car yet, probably I will return the unit to the suplier, I don't like to be deceived by the fanci videos that they put on net
Posted Aug 08, 2008 · 21:33 UTC#4
Olá,
I was considering and even had a F900BT on order, but after joinig this forum I gave up and ordered a Clarion MAX983HD. Yes, it's quite a bit more expensive, but you know what? It just works! Like advertised!
And, guess what? You will have music 5 seconds after turning the key and full control after 10 or so (they force you to read the disclaimer first...)
Check it out if you can. You can see pictures of my install in: http://www.avic411.com/forum/viewtopic.php?t=16635
Luis
Posted Aug 09, 2008 · 21:34 UTC#5
Olá,
Luis
olá luis
já vi a tua instalação o rádio é bem fixe quanto pagas-te por ele ?
para já falei com o vendedor do meu e amanha vou instalar o pioneer de uma maneira pouco usual para ver se resulta, se sim depois posto aqui o resultado em ingles para os restantes perceberem, se a instalação não der como penso que sim vou então devolver e provavelmente adquirir um igual ao teu
Posted Aug 10, 2008 · 00:41 UTC#6
Olá de novo,
Mandei vir tudo da www.caraudio-versand.de: MAX983HD+BLT583 (interface Bluetooth)+CCA692 (cabo iPOD) por mais ou menos 2000 euros. Tive desconto porque tinha a encomenda do F900BT há que tempos e a entrega estava sempre a ser atrasada.
Como é essa maneira pouco usual?
Posted Aug 10, 2008 · 20:51 UTC#7
ola, porque nao a kenwood dnx5220bt?
Posted Aug 10, 2008 · 21:07 UTC#8
Olha, porque detestei a interface. Andei a olhar para o 8220 e para o Pio HD3BT e ambos tinham uma interface não particularmente ergonómica e sobretudo não gostei do grafismo.
De resto, penso que os Kenwood estão entre os melhores. Têm ainda a vantagem de ter USB e saídas line level, coisas que o Clarion não tem.
Tem o disco de 40Gb em troca.
O facto de não ter saídas de linha não me trouxe problemas porque o meu amplificador Bose aceita entradas de nível de altifalante.
Posted Aug 11, 2008 · 09:25 UTC#9
Olá Luis
São boas opções, que irei ter em conta caso veja que o AVIC-F900BT não faça o que eu quero.
Mas para já nenhum me consegue fazer o voice command, foi uma das coisas que me deixou fulo com a Pioneer, andaram eles a colocar os videos na net e depois não disponibilizam para o mercado europeu, é caso para dizer DHAAA
Em relação á instalação a minha ideia consiste na alimentação do aparelho desde o momento que se desactiva o alarme e se abre as trancas das portas, sendo que o tempo que se demora a entar na viatura, colocar cinto etc. o sistema deverá estar completamente operacional, até porque não faz sentido a camara trazeira só estar operacional após o sistema navi estar activo, no final quando se sair do carro e activar o alarme e trancar as portas, aí é cortada a corrente e o aparelho desligar-se-á, esta solução é possivel até porque tenho um amigo que é engenheiro electotecnico, e vai desenvolver um módulo para este efeito,
Que achas ?
vou colocar esta opção no tópico em ingles.
Posted Aug 11, 2008 · 10:13 UTC#10
dear friends
in the past the weekend I installed the AVIC-F900BT, so far so good
I had an idea which may solve the slow start, I spoke with a friend of mine who is an electronic engineer
I asked him if it's possible using the remote command to opening the car door's cause the radio receives an immediate power, bypassing the ACC.
Then, as we enter the car and while you put the safety belt, almost 60" as past and the navy system should be operational at this time.
then when turning on the ignition this should not turn off the radio because of the bypass, and the radio still go on.
Finally, when we get out of the car and lock the doors with the remote command, the energy to the radio will be cut off, and the radio will shout down.
my friend says it's possible and will develop a module for this purpose
What do you think of this solution ?
Posted Aug 11, 2008 · 10:54 UTC#11
I think it sounds very good, it may actually become a nice workaround for the slow boot.
BTW the MAX983HD does have voice recognition, only not for Portuguese, Swedish and Danish...
Posted Aug 11, 2008 · 12:29 UTC#12
My simple solution is to choose the FM tuner before I turn the stereo off.
Then when you start the car, the system still take a minute to boot, but the radio comes on in the background after about 10 seconds. you can still control the volume, but thats it!
Posted Aug 11, 2008 · 13:43 UTC#13
Yeap, that´s true, I do the same when I shout out the system, but, look
I´m wondering, who was the smart guy in Pioneer who put the rear camera funcional only after the navy system boot up, the manual says it is for safety reason, does anyone in pioneer thinks that we will only go in backwards mode, and that's why we need first the GPS connected ????
Because with the system running this way, there must not be many people buying a rear camera
Then we still have the bluetooth question, that only begins to activate after the navy system be fully operational.
That's why I became with this solution
Posted Aug 11, 2008 · 16:23 UTC#14
obrigado,
but my car when starting the engine shutsdown the power to the radio. so i might look for a combination of your idea and a carpc m2-itx http://linitx.com/viewcategory.php?catid=56&pp=52,54,56 so over come the low voltage drop.
Posted Aug 11, 2008 · 16:54 UTC#15
obrigado,
but my car when starting the engine shutsdown the power to the radio. .......................
Ok that's why I mencioned the bypass on the ACC.
The principal idea is is to power on/off the radio using the remote control of the car doors.
To do so I'm gonna connect the radio to a kind of relay or switch that will give power (12V) only when the remote is pressed to open the car doors, and disconect when I lock doors using the same command.
By this connection when you start the engine, the power will never shutdown, because the connection is not there.
Posted Aug 11, 2008 · 23:34 UTC#16
We don't get the MAX983HD in the US. At least, there is nothing posted on our Clarion US site. Maybe in the near future we'll see it on the store shelves.
I read the specs and saw the pics on the UK site, and it looks like a good unit.
Posted Aug 12, 2008 · 00:21 UTC#17
Correct. You would need to install:
http://www.clarion.com/us/en/products/2 ... 77897.html
and
http://www.clarion.com/us/en/products/2 ... 78067.html
to get similar functionality, minus the hard drive (for music, navigation is still HD based) and added by USB interface.
It is not to be forgotten that Clarion owned McIntosh from 1990 until 2003 and profited a lot from their technology, meaning sound quality is actually very good indeed, and quite an improvement over the original head unit I had.
Posted Aug 16, 2008 · 23:43 UTC#18
one week as past since the instalation, and so far so god.
I've got a Honda Civic Hybrid 07 and I isolated all doors with Dynamat, and now the interior sound is great, I can't even ear the tires rolling.
As you know, european version don't have vioce recognition, so, with this isolation I be able to use the voice command from microsoft, that I have installed long time ago in my PPC QTEK 9090 and then by bluetooth the F900 do the call.
other thing that works fine is the PS2, for her I used the AV1 connection, now I can see all separately, same video or same game in booth monitors (front and rear) or video in front and video in rear, or vice versa.
the microphone as poor voice sound and most of the time, people on the other side of the line can't ear clearly, so I correct this by installing a kind of little umbrella in the base of the microphone to amplifi the voice, and it works.
one of the things, I didn't discover yet, is how to made apear in the map those 3D images of the monuments.
