I'd really love to eliminate that safety message that comes up every time you first go into the Map screen. I've tried finding it a few times, without luck yet, but I know it's in there somewhere. The more I think about it, the more I think it's something we (the community) *should* be able to defeat. I'm posting this in hopes of either getting some feedback, or providing the clues needed for someone else to locate it.
Here's the facts, as far as I am aware:
1. The iGo software starts automatically when the nav unit turns on.
2. The safety message only appears when you try to go into the Map screen (If your last screen was the map, then the safety message appears automatically of course.)
3. The safety message does not appear every time you switch to the map screen, only the first time for that 'session'.
4. The data.zip has a number of ui files which contain clues that refer to the safety message.
5. The clues point to a directory and an xml file, but I cannot find those in data.zip or on the nav unit. They might be hidden, or might be 'hardcoded' into the executables.
6. There must be a 'first run' or 'first view' variable, so the thing knows to show the safety message only the first time in each session.
With those facts, I am thinking of two ways to proceed, in order to defeat that message.
A) I know which ui file contains the script that *I think* launches and dismisses the safety message. I could hack that script and maybe it would trick the nav unit into thinking the message was displayed and OKed instantly, so the message would never actually appear.
Although I have not found it, there must be a variable that indicates either the safety message has already been shown, or that the map is displaying for the first time. In either case, if we can find the variable we can put in whatever will make it happy, so the safety message does not come up.
Naturally there's some amount of trial-and-error required, testing back and forth. On the other hand, like everyone else, I am not looking to 'brick' my shiney new nav unit!
So I don't tend to actually test something unless I'm either certain it will work, or certain that it won't cause any permanent damage.
Anyhow - that's pretty much all the information I have right now, about the safety message. I'm eager to hear what you all have to say.
Cheers!
