just wondering if the F-series can shows the chinese text or not?
can F-Series shows the Chinese text?
Been discussed. US units don't support chinese characters. Unless you can find a way to incorporate the characters to be used with the unit, theres no way.
thx for reply
i did a search but i didnt see any post were talking about it
maybe just i didnt find it
but thx anyways hahaha
I haven't tried it, but adding fonts that include Chinese characters (probably to windows/fonts) directory might work...
thx for replyi did a search but i didnt see any post were talking about it
Did you manage to get Chinese text working?
Adding the Unicode fonts to the Windows directory should technically work, since I recently got Chinese text working on my PocketPC (Windows Mobile 2003). But in order for it to work properly under Windows CE I think you will need to use Font Linking, which involves editing the registry. Please see following links: -
http://msdn.microsoft.com/en-us/library/aa913850.aspx
http://msdn.microsoft.com/en-us/library/ms901083.aspx
On my PocketPC I transfered over the "mingliu.ttc" font file from my computer, which contained Japanese, Traditional and Simplified Chinese. Then I added the following key as explained in teh article...
"HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\FontLink\SystemLink"
The link I posted talks about adding a SkipTable registry key, which I didn't do and Chinese still works fine on my PocketPC. Here is one more link that helped me... http://www.geocities.com/grieg_winter/v ... index.html
Just want to be clear that what I explained above was for PocketPC but since the unit uses Windows CE it should technically work.
So in theory, if we use the method discuss by Redalert + method from here,
http://www.avic411.com/forum/viewtopic. ... ht=chinese
it shoudl works , since it enable the system.nls to read chinese and set the registry for it.
someone wanna try it out ?
