HOW TO: Add Branded POI icons :UPDATED: 04-21-09
By VBLUE42 · Oct 07, 2008in Hacks/Mods💬 259 posts👁️ 153,793 views
Page 8 of 11
Posted May 15, 2009 · 21:54 UTC#176
I'm not too sure which one you mean.
Posted May 15, 2009 · 22:43 UTC#177
found it, thanks
Posted May 15, 2009 · 23:02 UTC#178
NP
Posted May 20, 2009 · 22:54 UTC#179
I am getting an error now that I did not have before. When I go into the "Manage POI" screen and I start to scroll through the .bmps I get to about the third screen where most of the fast food bitmaps reside and I am getting an error that says:
"Failed To Open file:
$poi_Fast_Food.spr
exiting application"
I updated the Maps to 2008.4 recently and also the 2008.10 POIs which are supposed to be compatable..
I am confused now :oops:
Thanx for the help,
Bud
Posted May 21, 2009 · 05:32 UTC#180
Fixed It ;)
Posted Jun 10, 2009 · 19:12 UTC#181
Is the size of the POI that is displayed on the screen related to the Stripes number? is there a maxium size you can use? Most are 30 or 32, can you go 35 or 40?
Posted Jun 10, 2009 · 19:52 UTC#182
More or less... Stripes parameter tells software how tall in individual icon in the image file is, so stripes value should be based on pictures you use.
You can use 40,60 or whatever, but unless you also change image files accordingly you'll get pieces of icons al over the place... There is no scaling of POI icons, so you can't make them larger or smaller on the fly...
Posted Jun 10, 2009 · 20:44 UTC#183
Thanks for the info BorisM
Posted Jun 10, 2009 · 21:28 UTC#184
You're welcome.
Posted Jun 14, 2009 · 08:57 UTC#185
I downloaded the branding.zip, i took a quick view in it and saw a lot of duplicate files and a folder wit resolution 480*272, where pioneer has 800*480, anyone knows whar effect his has.
I'm currently using eu 2009.2 maps is the file working with this?
Posted Jun 14, 2009 · 09:02 UTC#186
The duplicates and folder have no negative affects.
Posted Jun 24, 2009 · 20:08 UTC#187
it's a pity their all american and not european...
Posted Jun 24, 2009 · 20:34 UTC#188
Check out something like http://www.i-go8.com/ <- finding European branding for iGO is much easier than US.
Posted Sep 05, 2009 · 17:33 UTC#189
I cleaned up all the double files in VBlue's posted file. It is knocked down to 2.3MB.
ftp://avic:[email protected]/Branding.zip
Does anyone know if this branding.zip work with Pioneers new firmware 3.01?
Posted Sep 05, 2009 · 17:37 UTC#190
People have posted that they are using it with the new firmware with both the F and X series units.
Posted Sep 06, 2009 · 04:19 UTC#191
Works just fine.
Posted Oct 04, 2009 · 23:28 UTC#192
I installed the branding.zip from post#1 on 3.01. I am having some of the fast food icons showing up transparent on the map (ie McDonalds, etc). Does anyone know how to fix this?
Also, if anyone can shed some light on how to add more icons for the ones missing, I would be happy to try and fill them in a bit more.
Thanks for the help.
Jason
Posted Oct 12, 2009 · 17:37 UTC#193
I installed the branding.zip and it works perfect. The laneinfosigns are now darkgreen instead of blue. Is it possible to turn them back to blue, cause in europe they are most of the time blue.
Please tell me how to change this.
Rob: F900BT with version 3.000300
Posted Oct 12, 2009 · 19:44 UTC#194
In COMMON folder there is a file laneinfo_signpost.ini which might have color settings (RGB) for shields. If there's nothing there, shields are European-default blue. For US we need to add a color line there that changes them to green.
If branding.zip has this file, it overrides one in DATA.ZIP, so just delete it from there.
Also, for Europe there are craploads of branding files that are good, unlike US where this one is the only decent one available. Check something like http://www.i-go8.com
Posted Oct 13, 2009 · 00:14 UTC#195
Why are some of the icons transparent?
Posted Oct 13, 2009 · 07:46 UTC#196
Is there a site that has branded icons for the UK,ie Asda,Tesco etc.Thanks.
Posted Oct 13, 2009 · 16:29 UTC#197
Same i-go8.com should have some.
Posted Oct 13, 2009 · 16:58 UTC#198
Thank you Boris.
Posted Oct 13, 2009 · 18:03 UTC#199
http://www.i-go8.com/2008/08/igo-8-uk-p ... ns-in.html
Boris I have tried to download the icons from the above link but I don't know where they are going.I hate that upload 2 site as i can never manage to download any files.Can you suggest anywhere else i can get the file?Thanks.
Posted Oct 13, 2009 · 18:35 UTC#200
The location the branding file should be installed in is in the first post.
Page 8 of 11
