LeetLauncher v3.0!!!
By leetcoder · Oct 11, 2008in Completed Mods/Themes💬 844 posts👁️ 380,404 views
Page 29 of 34
Posted Jul 04, 2009 · 15:02 UTC#701
Hello everyone, I'm from Greece and I've been reading this forum for a long time but i guess it is time i should start posting too. Can someone tell me the exact files LeetLauncher v2 and v3 are creating in the unit? I have noticed that when i save a location in the original avic software OR in the launcher with iGo 8.3, the save is accessible by both programs and that means it is stored in the flash memory. What other files are affected by the launcher? I assume that for waranty reasons and/or for update reasons, those files would eventually have to be removed.
The next release i'll be sure to include something that can help you remove these files.
Posted Jul 05, 2009 · 06:33 UTC#702
quick question leet if i am running the 1.5 launcher can i just extract the 3.0 version onto my card and replace it and have it working? thanx
Posted Jul 05, 2009 · 12:42 UTC#703
3.0 requires a set of xml files for it's albums - so yes it will work, but some additional steps are needed to have it scroll through the different album arts/etc on the coreplayer views.
I'm not sure if the location for the maps and other content has changed, but I know that has.
Posted Jul 06, 2009 · 20:09 UTC#704
Hello.
There will be a new version of LeetLauncher give a new test mode for Pioneer AVIC F900BT Software Version 2.007000, because the 3.0 version goes with the new software no longer works.
mfg.hunter25990
I replace the new files of the test mode 2.3 in the leetlauncher and it works but it doesn't launch the leetlauncher at start and i don't know what to do.
Posted Jul 06, 2009 · 21:10 UTC#705
I'm trying to activate Garmin XT but I can't figure out how to get my Unit ID. I was able to get into the system -> about menu and find the device ID. I popped the deviceID into IMEI_converter.exe but it claims my deviceID is invalid. My device ID is 1610781417. Can someone confirm if I'm using the right device ID as the IMEI? If you could convert it for me then that would be even better. Thanks.
Posted Jul 06, 2009 · 21:24 UTC#706
In your next release. will you have all bugs for the F500BT fixed ?
Posted Jul 07, 2009 · 20:13 UTC#707
Leet, please help us with the new testmode 2.3 for the leetlauncher.
Posted Jul 07, 2009 · 23:12 UTC#708
Neto, try copying all of the files with names made up of nothing but numbers (i.e. "164C549550B84211BA8C4B84AC5C0081", "63D21BEFE088433dBE3CF942347464C7") from the Testmode 2.3's "testmode" folder into Leetlauncher 3.0's "Testmode" folder. This is assuming you have 2 different SD cards, or 2 different working directories (one for TestMode 2.3, one for LeetLauncher 3) on your computer.
If that doesn't work, you might want to copy "CopyTool.exe", "MortScript.exe" and "NNTestmode.exe" from Testmode 2.3's "testmode" folder to Leetlauncher 3.0's "Testmode" folder. Then rename Leetlauncher 3.0's "NNtestmode.mscr" file to "CopyTool.mscr". From what I can tell, TestMode 2.3's CopyTool.exe is really a renamed MortRunner.exe, while in LeetLauncher 3 NNtestmode.exe is the renamed MortRunner.exe. Carver may be letting NNTestmode.exe run and call CopyTool.exe (a.k.a. MortRunner.exe) in order to satisfy a requirement for the test mode to work w/ 2.006.
Posted Jul 08, 2009 · 00:20 UTC#709
Thank you, you are rigth.
Posted Jul 08, 2009 · 14:57 UTC#710
I have working LeetLauncher 3.0 and Amigo 8.4 (iGo new version). Anybody need instructions? :)
Could you please send me the instructions too?
Posted Jul 08, 2009 · 15:44 UTC#711
I need help with the garmin xt. I can't get gps device. I don't know if i need the activation first?
Posted Jul 08, 2009 · 20:20 UTC#712
I activated and works but i have problems with garmin xt satelite signal. Few minutes after start has lost signal. Any tips?
Posted Jul 08, 2009 · 21:17 UTC#713
i was trying to get leetlauncher to work with my Avic F90BT, but when i downloaded the v3 and unzip the file into the root folder of my SD card, the Avic just boots up normally. Do i need to enter testmode to install leetlauncher v3 or does it automatically install?
Posted Jul 09, 2009 · 06:37 UTC#714
yes, please :)
thanks
Posted Jul 12, 2009 · 00:36 UTC#715
Help !!! how to use Igo 8.4 ( Amigo ) with the leetlauncher 3.0
Thanks... :)
Posted Jul 12, 2009 · 03:23 UTC#716
As far as I know, Amigo doesn't support native 800x480 yet. However, if you want to have it running, there is another way to stretch 400x240 skin. To do so, add those lines in sys.txt:
[interface]
resolution_dir="400_240"
vga=1
[rawdisplay]
class="landscape"
screen_x=800
screen_y=480
class="landscape"
high_res=1
The quality is not good, but works really fast : )
Posted Jul 13, 2009 · 03:16 UTC#718
Ok guys I dont know what Im doinf wrong here. I have never played much with my F500BT much except today. I upgraded to the latest firmware 2.6 or what ever.
Im trying to get LeetLauncher to work. I have a freshly formatted SD card that im extracting LeetLauncher 3.0 onto.
Im installing the SD card into the f500BT and nothing happens. I can see the files in the tree ect. Is something supposed to autorun? Do I need to do something else. I have been at this for hours now. :? I have been playing with Test Mode and know all about that. I just dont know why my leetlauncher does nothing at all?
PS: if I run leetlauncher in testmode I get to "system is starting up please wait"
edit: I got it working... Duh,,, when I exctracted the .zip file to my SD card the folder structure was incorrect. All the sub folders were in the 3.0 folder :P
Posted Jul 13, 2009 · 05:58 UTC#719
I have some skipping problems while playing divx movies using the mediaplayer from leetlauncher. Divx files run smoothly on avic's original mediaplayer but it cannot fast forward/rewind or stretch to full screen. Does anyone know what the problem might be? Any idea how to fix it? Thanks.
Posted Jul 15, 2009 · 16:23 UTC#720
Hello, I would like to know if its possible to install the LeetLaucher on the Nand Flash of the unit, so I'm not going to use the sd card anymore,
thanks for your atenttion!
Posted Jul 15, 2009 · 16:26 UTC#721
do you mean - Is it possible to install it directly on the unit? if so... not really maps are 4gb+ so that part would not fit... you can maybe repoint the maps to a usb drive/memory stick, but then you'll need to also modify the autorun to point to leetlauncher instead of pioneer launcher.
Posted Jul 15, 2009 · 16:41 UTC#722
is exactly what I mean, my map of brazil have only 100 mb and I want to use only with IGO 8.3, do you know how to modify the autorun to point to leetlauncher instead of pioneer launcher ?
Posted Jul 15, 2009 · 19:14 UTC#723
Does any body knows if i update the win CE with the update 3.0 like other forums, leetlauncher works?
Posted Jul 15, 2009 · 23:26 UTC#724
Yea, LeetLauncher 3.0 works fine with the newest WinCE and 3.010 firmware. Here's how to fix the autolaunch problem:
1) Download LeetLauncher here: http://www.avic411.com/forum/viewtopic.php?f=34&t=18522#p123463
2) Download TESTMODE 2.3 here: http://www.avic411.com/forum/viewtopic.php?f=34&t=25367#p172474
3) Delete ALL files in Leet's testmode folder and replace them with the Testmode 2.3 files
4) Open CopyTool.mscr in notpad and erase all the text (optional, but makes it much faster)
5) Add this code to CopyTool.mscr and save:
Run(SystemPath("ScriptPath")\"..\LeetLauncher\LeetLauncher.exe")
Posted Jul 16, 2009 · 09:28 UTC#725
Just did a little donation, seems like a great software and would love to see new releases :)
Page 29 of 34
