CNDV-80MT update epic fail on the avic-d3
By mayuan · Oct 13, 2008in Problems/Troubleshooting💬 35 posts👁️ 12,230 views
Page 1 of 2
Posted Oct 13, 2008 · 22:43 UTC#1
So, I updated the software using the CNDV-80MT download. the system seemed to update just fine.
After the update the system did not work. the screen says please insert approprate disk. Now nothing works at all. When I load a disk in the system, the system checks it then rejects it.
Any help would be great!
Posted Oct 13, 2008 · 23:16 UTC#2
Reset the unit and it should work
Posted Oct 14, 2008 · 00:04 UTC#3
I assume you mean hit the reset button on the front? I pushed it and still nothing.
Posted Oct 14, 2008 · 21:57 UTC#4
same problem here
Posted Oct 14, 2008 · 22:24 UTC#5
i've seen them work on a d3 i made a disk for another member on this board and at first it didn't work the we put the one out of my d1 in and work noproblem and his disk worked in my d1 so we were both happy
Posted Oct 15, 2008 · 18:32 UTC#6
I too am experiencing problems with update I DL from this forum. I cant even acess any of the new background images from the disc, and I still have the same images from the initial disc still being displayed!!!! is there any way to DOWNGRADE my radio back to the factory firmware?!!!
Posted Oct 17, 2008 · 15:38 UTC#7
You may have a corrupted copy. East upgraded my firmware (AVIC-D1) but then wouldn't load. I downloaded it again, unzipped it and burned it and it worked this time.
I have ordered the disks from Pioneer anyway. They are production DVDs pressed from a glass master and are more reliable than your burned copies. Do you really want to trust a home burned dual layer disk on a long trip?
Plus you might have difficulty explaining it to the cops if they want to mess with you. They charged some guys recently for a "van full of bootlegs":
http://www.gwinnettdailypost.com/main.a ... nID=84&S=1
Posted Oct 17, 2008 · 16:40 UTC#8
I also downloaded the two iso's and had some difficulties as well. I initially used memorex dvd's and used 3 of them and could not get any of them to burn past 50 percent. I them bought some verbatim disks and was able to burn the east and wesk iso's using Imgburn. When I inserted the west disk into my d3, it seemed to be updating fine, it even said update complete and showed the new map version after resetting. After a few minutes of the map being displayed, it locked up and displayed "insert appropriate disk". I tried resetting several times, but nothing helped. I tried the new east disk and it updated just fine. I decided to burn the west disk again, except used alcohol120 the second time and it burned and updated the d3 just fine and haven't had any problems yet (its only been 1 day though).
I think getting a good burn is why so many people are having a problem with the update. For those having problems updating, I would try a different brand of disk and/or a different burning program.
Posted Oct 17, 2008 · 17:36 UTC#9
Anytime you don't buy the "retail" version of software, you run the risk of having problems. It's just a roll of the dice, sometimes it works , sometimes it doesn't. Can't really complain if you didn't pay for the software, just work through it and you will eventually find a good "copy".
Posted Oct 17, 2008 · 17:39 UTC#10
I was having similar and even more tragic results:
my unit was fairly FUBAR'd by either an incomplete download/upgrade from the previous update file posted on the forum from a the "N" model. probably my error since it worked for others. I was able to DL this file and burn the image to a disc using PowerISO. I reset my unit using the reset porthole on the upper left of the unit by the eject button with the new disc inserted. After the unit 'rebooted' it updated again -completely this time- and it works with all of the pre-upgrade functions (map icons and function etc etc etc). the unit starts faster when I turn on my car and it has 2008 copyright from pioneer as well 5/2008 from telatlas and infousa.
THANK YOU SO MUCH for posting the actual discs! I would also like to thank the people who posted the original disc even though it did not work for me. I appreciate being part of a community that has members that go way above beyond my greatest expectation of an online association. In kind, I do graphic design work and would be willing to, in my limited time, pay it forward by helping create a few backgrounds for those that may want/need them.
Posted Oct 17, 2008 · 22:05 UTC#11
Well, so far I've tried about 5 disks and several different burning apps. I'm now trying the Alcohol 120 on my Memorex. If it doesn't work, I'm going to search for some Verbatims.
Geez, I hope I can get this to work soon as I now can't even listen to radio or anything.
Bummed a bit,
Bryan
Posted Oct 17, 2008 · 23:38 UTC#12
dam so if the disk is bad the d3 wont let u listen even to the fm radio??? :shock:
Posted Oct 17, 2008 · 23:44 UTC#13
Yeah, pretty much. Once is is fucked up (insert appropriate disc), it is fucked up until you get the right readable disc in there.
I've tried the East disc, burned at least half a dozen times. Memorex, Verbatim, and Sony. All a bunch of damn coasters now.
I give up...just hope one of these dudes that can burn them clean will sell me 2 copies at this point since Pioneer is backordered until mid-December....PUNKS.
Bryan
Posted Oct 17, 2008 · 23:45 UTC#14
Bryan
Posted Oct 18, 2008 · 00:16 UTC#15
I have burned about 5 east disks with no problem.I use sony dl disks with power iso.
Posted Oct 18, 2008 · 00:22 UTC#16
So, would you be welling to sell me a copy? At least until I get both from Pioneer at some point in the future?
Posted Oct 18, 2008 · 01:28 UTC#17
pm me
Posted Oct 18, 2008 · 12:23 UTC#18
My D1 took Memorex and Verbatim burned with Nero. You can run MD5Deep on the ISO file once you download it to verify that it is valid. The values I get from my download are:
East:
d3b6726fc455fcd77736b38c0f222163
8,166,578,176 bytes (right click -> properties)
West:
6cad7ae2479d452043b60cd440d20546
8,518,647,808 bytes
Posted Oct 19, 2008 · 04:04 UTC#19
im at my wits end, yet so glad for these forums...
so far though, ive burned damn near $30 in disks trying alcohol, power iso, nero, you name it... unfortunately, i get a write failure every time i try to burn w/ alcohol120...
ive got no nav, have the "please insert appropriate disk" error whenever trying to access my maps.
ive tried so many disks, reset so many darn times.. its frustrating to no end.
fortunately, im able to access my radio & ipod screen, but no nav makes me sad.
ive been reading thru these forums for days now & seems everyone w/ a problem got theirs fixed somehow....any tips, guys?
Posted Oct 19, 2008 · 04:08 UTC#20
Hey, how did you get the iPod and radio back after the "insert disc" garbage. I can't figure out how to get back to that or even turn the damn thing off until I can get a good disc to complete the update.
All I've got is this damn thing shining the grey dialog box "insert appropriate disc". Resets, $50 in discs, and nada!
Thanks,
Bryan
Posted Oct 19, 2008 · 04:14 UTC#21
well naturally, i just began mashing all the buttons while cursing at it....
excessively.
i think it had to do tho with pressing the center button & mebbe resetting it 400 times.
good luck!
Posted Oct 19, 2008 · 04:49 UTC#22
Yeah, I've tried that route...so far nothing but more of the same. I may give it a good smashing tomorrow!! Certified POS. Why can't they make the firmware update process simply NOT update, until the disk contents has been verified. What would that cost, like an extra nickel in memory if anything?
Posted Nov 09, 2008 · 05:36 UTC#23
Any updates? I tried to roll back to old software and it won't take GPS application. This sux!
Posted Nov 09, 2008 · 07:10 UTC#24
got the burned cd version the other week & it all worked liek a CHARM!!! thansk so much.. really, it all boils down to a good quality burn on the right DVD.
i love the new features...especially the map going negative style when the lights are on... and the muting of music playing for the voice directions.. sweeeet!
Posted Nov 09, 2008 · 22:57 UTC#25
well those are normal features that can be turned on or off.... But for those that want the original dvd back i managed to get it to work. Someone said something about switching languages and I did that and it worked!!! But sadly I can not access the information on the cd player. It still plays but when I hit source it goes to the cd a/v menu.
Page 1 of 2
