I am experiencing with software problem on my AVIC-F900BT & was wondering if anyone would like to help me out with it. I am willing to pay as long as the problem gets fixed for good!!
Could I please get some help in the San Diego area??
Well what problems are you experiencing?
well, when i installed the radio & tried to bypass it, it worked fine for a day & then it started to reset itself over & over while I was driving. When I am at a set place, it works fine. I hooked everything back up the way is supposed to do with no wire bypass & it still didn't work. So what I did was, disconnect the Navi antenna & it works great except no navigation. How could I fix this & is there a way the software could be bypass???
did you try a hard reset? hold eject and press reset it back to day 1.
The bypass, if done correctly, would not have done that.
Yes there is a software bypass. http://www.avic411.com/forum/viewtopic.php?t=17715
I just tried the reset & that didn't work. Now, I want to do the software thing but I really don't understand it. How do I put my deck in test mode? How do I change that file step by step?
All of your questions regarding all hacks, can be found in the sticky at the top of the mods forum.
http://avic411.com/forum/viewtopic.php?t=18327
Good luck
Thanks you guys!! I finally figured out was I am doing & hopefully I will fix my problem.
Still doesn't work. I did the software bypass & it still resets itself after 10 seconds of me driving the car. Any ideas???
Is your harness connections loose? You say its fine when your not moving, so maybe when you do start driving a ground wire or power wire looses its connection.
No. I double check the wiring & its fine. It works great when I unhook the GPS antenna so its something with the software.
