IN PROGRESS: Fixing up Samantha
By Yettavr6 · Oct 31, 2008in Hacks/Mods💬 129 posts👁️ 35,128 views
Page 5 of 6
Posted May 17, 2009 · 18:18 UTC#101
I use Fairstars audio converter to convert to OGG, but there are many other programs that work as well. Just save it in the same format as all the other OGGs, mono 22kHz 48kbps. You can see the marvin ones I added, just name yours the same as those.
Posted May 17, 2009 · 19:27 UTC#102
Ok, so what am i missing here? I used SamHybrid-Auto.zip and she doesn't even attempt to say any road names. Did I use the wrong voice? She still sounds pretty staticy/scratchy still so i'll probably just stick with Jason, but if I did something wrong or used the wrong file I'd like to give it another shot.
Posted May 17, 2009 · 21:09 UTC#103
I am having the same issue as reported by 'FF' where the 'Take the next right/left' sounds like 'Take thnext right/left'. The entire word 'the' is not enunciated. Just curious if anyone else is having this problem. Also, how can I reset everything back to the default as far as the mods go just for the TTS on the GPS? Thanks in advance!
Posted May 17, 2009 · 21:55 UTC#104
CMH928: I think I found the issue with the TTS saying 'Take thenext left/right'. I noticed in the rules.ini file for the TTY, you don't have spaces before the following lines:
/(^|\s)?turn right\b/i/-->" turn-rite "
/(^|\s)?turn left\b/i/-->" turn-left "
/(^|\s)?next right\b/i/-->" next-rite "
/(^|\s)?next left\b/i/-->" next-left "
I assume a space indicates to the TTS to have a brief pause. Anyway, I changed that and it seemed to work. I have no clue what I'm doing, but wanted your input.
Posted May 18, 2009 · 04:32 UTC#105
Gooch, if you're using the hybrid, those rules are ignored anyhow. The voices are pre-recorded. To alter them you'd need to change the OGG files.
Yetta, what maps are you using? Stock 2007.10 maps have the best naming. 2008.4 is flaky when it comes to highway names being spoken. 2008.10 just doesn't work.
Posted May 18, 2009 · 14:35 UTC#106
I'm using the 2008.4 (didn't know there was a 2008.10). I haven't tried any highways yet, but just regular roads around here, it shows the name fine on the screen, but Samantha just says "Turn right in xx feet" or "take the next right". I couldn't get her to say a single street name.
Posted May 18, 2009 · 20:53 UTC#107
Here's one. Yesterday I was getting on the the freeway (I-15 N.B.) and Samantha said "in more than 1/4 mile turn left onto I"-.. what, no "15" ? But, when I get closer she will say "turn onto I-fifteen" I know that she used to say it correctly before I updated my maps to 2008.4 from the 2007.10 that came with the F90BT.
Is there a fix for this?
Thanx,
Bud
Posted May 18, 2009 · 21:15 UTC#108
Thanx,
Bud
It does it to me too. It really doesn't bother me too much, though. I guess we will just have to live with it until the next rounds of maps come out or revert back to the older maps.
Posted May 18, 2009 · 23:45 UTC#109
I'd revert back but then I lose use of the 2008.10 POI's.
Oh well.
Posted Jun 04, 2009 · 14:16 UTC#110
Love the new Samantha. One funny problem though is, with street names like:
"148th Ave NE" (One hundred forty-eighth avenue northeast)
Samantha pronounces that as "One Hundred forty-eighth avenue Nebraska"
Which is, you know, humorous...is there a way to fix that? Street names that begin with NE, as in "NE Union Hill Rd", are pronounced correctly.
I looked over the files in \config but there's nothing in rules.ini or any of the .csv's that seem to override this.
Posted Jun 05, 2009 · 01:12 UTC#112
Well, since nobody else seems to care much about TTS anymore, here ya go, Doogie.
No guarantees.
ftp://avic:[email protected] ... e-Auto.zip
cmh, I just tried it out in a simulation, and I have to say it did make a difference in her speaking a lot better. I will know more when I get on the road tomorrow. Thanks.
Now, if I could just leave my unit alone for one day....
Posted Jun 05, 2009 · 03:19 UTC#113
Yeah, no joke. Thanks cmh..much appreciated. I'll dig in and see what's different, hopefully make a contribution here rather than just taking others work.
Posted Jun 17, 2009 · 20:02 UTC#114
Please forgive my newbieness, but I seem to have lost Samantha. All I get is Jason, whether I choose his voice or Samantha's. Don't get me wrong, he sounds way better than the stock Samantha my Avic came with, and again hats off to cmh928 for the mod that makes the avic worth keeping, but I miss a female voice. I have tried the other languages and you can tell the voice quality is way better. However, I have also lost the street names. So instead of saying "turn onto I-95, north" it now says "prepare to exit highway" If I choose French or Spanish, the street names are still there.
Posted Jun 19, 2009 · 02:22 UTC#115
No guarantees.
Me, me, me! I still care. Is this still the hybrid version?
Posted Jun 27, 2009 · 01:27 UTC#116
Oh well.
How do you go about reverting to the 2007.10 maps? I tried simply overwriting my 2008.04 California map with the 2007.10 California map file, but when it booted I just had the green basemaps and no streets.
Also, why do you lose the 2008.10 POI's if you downgrade from the 2008.04 maps to the 2007.10 maps?
Posted Jun 27, 2009 · 03:16 UTC#117
Oh well.
Are you sure you didn't put the California POI file in the California map location???
Posted Jun 27, 2009 · 06:08 UTC#118
Oh well.
I didn't replace the california poi file, just the california map file. And, I checked, I did put it in the correct place. So i was running the 2007.10 california map file and the 2008.10 CA poi file.
Posted Jun 27, 2009 · 11:50 UTC#119
Did you make sure that you didn't put the POI file in the map folder? I actually did it once and the same thing happened to me. Also some versions of maps don't work with other versions of poi. There is a whole bunch of threads regarding maps changes and poi's. Check those out, as this thread is for samantha changes.
Posted Jun 27, 2009 · 20:56 UTC#120
Check again, because the poi and map files carry the same extention.. .fbl. I actually did it once and the same thing happened to me. Also some versions of maps don't work with other versions of poi. There is a whole bunch of threads regarding maps changes and poi's. Check those out, as this thread is for samantha changes.
Please!
Maps are .FBL. POI files are .POI. They do NOT have the same extension.
Posted Jun 27, 2009 · 21:11 UTC#121
Please!
Sorry. What i meant was, when I downloaded both POI and maps at the same time, I accidently put the POI file in the map folder. I was thinking that he may have done that. My mistake.
Posted Jun 28, 2009 · 18:15 UTC#122
Ah, that it might be...
Posted Jun 29, 2009 · 22:11 UTC#123
I posted it here because CMH928 was saying that Samantha works best in 2007.10, and 69sixpackbee said that if he reverted back to 2007.10 he would loose the use of 2008.10 POIs. I will ask in the maps thread about compatibility between 2007.10 maps and 2008.10 pois. Cheers.
Posted Jul 01, 2009 · 01:15 UTC#124
Quick question i cant find here. I dont even see Samantha on my f700bt. is that even an option for this unit?
Posted Aug 20, 2009 · 12:54 UTC#125
Could some one has the fixed Samantha TTS file and MarvinHybrid TTS please re-upload the files again?
The old links are not working any longer.
Thx
Page 5 of 6
