f90bt keeps saying "please wait" then reboots
By tacoavic · Oct 31, 2008in Problems/Troubleshooting💬 8 posts👁️ 1,377 views
Posted Oct 31, 2008 · 05:40 UTC#1
i just did the update and everything was working fine. i modded a data.zip folder and place it in. it boots that hangs at "please wait" then reboots. i have a backup of "My flash drive" should i copy the folders from my "storage disk to "my Flash drive"?
Posted Oct 31, 2008 · 05:57 UTC#2
how do i get the unit back to factory default?
Posted Oct 31, 2008 · 06:51 UTC#3
i panic. but all is good. i copied "My flash Drive" back up to the HU's "My flash drive" and everything worked. not gonna mod this unit for now. whew.
Posted Nov 04, 2008 · 01:47 UTC#4
I haven't modded my unit at all except for doing the wire bypass of the unit. My radio just started doing this today... I haven't done any firmware updates. Any ideas? There's no interruption of sound when listening to my XM but it reboots over and over again.
Posted Nov 04, 2008 · 14:17 UTC#5
Just tried the update. The update process appeared to work as it should but following the install it just went back to rebooting itself time and time again.
Any ideas folks?
Posted Nov 10, 2008 · 13:18 UTC#7
After update I had problem too that device kept resetting itself after couple of minutes, also I wasn't able to access map/navigation. This problem was caused by USB key(Kingston 16GB); if USB key is connected when device is started, it will keep resetting itself; if I first start device and then connect USB key, everything works perfectly.
Posted Nov 16, 2008 · 21:54 UTC#8
I had nothing connected to mine. It was internal and had to go back to where I bought it. I got set up with a new unit on exchange. Fortunately for me, this happened in under 30 days so I was able to get an over the counter exchange.
