OK - so I'm updating to FW 2.0 and everything is going fine - update progresses to the point I have to reset so I can go on to the Bluetooth part of the upgrade. On reboot and after the splash screen I get a Fatal Application Error "Application ezrider has performed an illegal operation and will be shut down..." Numerous attempts to reset (both with reset alone and reset with eject) always gets me to the exact same error message. Main menu screen stays stuck on the normal startup message after closing out the error message. Most functions (like listening to the radio) will work for a bit, then lock up on the same error message. I've a message in to Pioneer, but they won't get back to me for a while. Ideas??? F90BT with 1.001700 was what I was trying to upgrade to 2.0 from...
BTW, great forum - I've been lurking for a while and searched hard for a fix before posting (this is not the same problem some others have had with BT pairing), so apologize in advance for this first post (used to sharing good news, not problems). TIA for any help, guys!
