does anybody know how to hack AVIC-F900BT to make the dvd player region free?
how to hack US AVIC-F900BT to work in Europe??
I have bought it in US, what can I do, or
install to work in Europe, and is the hardware the same?
Can I update it just with Europe firmware?
iz this true!??
1. Pioneer currently does not offer European or US maps for US or European consumers respectively.
2. The US product will not work to satisfaction in Europe.:
TMC will not work
No RDS
Differnent FM channel spacing
Different AM channel spacing.
3. Firmware Does NOT include the map data.
And firmware is different between US and Europe.
Yes, all of that is true.
Since the unit is running on Windows platform, I think the best way is to find patch software that will remove the region code check. I use those patch on my home PC. I will try to search for it.
Thank you for that. I hope you will be able to find it. It will help all the buyers from Europe.
If anyone else knows something about this subject, feel free to write! ![]()
Also you can try to edit file \User\SystemData\uComInitComm\ModelVersionInfo.txt. This file contains following line:
MiconVer=08.09------яDvdVer=02.01.05.00яRegionCode=Sys5 Mecha5я
I don't test it yet, but may be changing RegionCode in this file take effect.
what is means Differnent FM channel spacing ??
in europe I can listen the radio fm!!??
Don't you call it UHF in Europe?
I don`t know exactelly, but I think that it is called the same.
Frequency difference between stations in FM is different between US and rest of the world, and also the highest/lowest frequency on FM is different as well. So normally a tuner designed for US will no receiveEuropean broadcasts and vice versa.
Sorry markostilo, I could not find anything for CE. Maybe you just work around it for now by decoding your dvd to mpeg files, then burn them back to code free dvd. If you need on that, just check videohelp.com
i also worked a bit on similar subject,running european maps on us unit but i coould not find a european f700-bt licence file,nobody uploaded it and i'm stuck with it. if anybody can upload it,it helps a lot.
thenks man maybi somebody else find solution!
dose enyone knows it is posible to hack or do something else to activate fm radio tu work in eu!??
Anyone know what will hepend if i instal europian firmware on usa unit!??
does anybody know how to hack AVIC-F900BT to make the dvd player region free??
Because junit workt on WinCE maybe we should be we should be to replace with euro region cod!!
hello friend,
Just see this topic:
http://www.avic411.com/forum/viewtopic. ... sc&start=0
It has the licences you need. Try and tell us the result ![]()
hello friend,
This has absolutely nothing to do with the original question.
I doubt you can reflash DVD drive with RPC-free firmware without taking the thing apart and I have never heard of region-free players for WinCE, but there may be something out there...
Also you can try to edit file \User\SystemData\uComInitComm\ModelVersionInfo.txt. This file contains following line:MiconVer=08.09------ÑDvdVer=02.01.05.00ÑRegionCode=Sys5 Mecha5Ñ
Is the above line from US or EU model?
If someone with the EU unit could post exact same line we could perhaps compare them and try to change them.
Would that be possible? ![]()
Hi Stan,
Just copied this from my UK F900BT, hope it helps.
MiconVer=08.09------ÿDvdVer=02.01.05.00ÿRegionCode=Sys2 Mecha2ÿ
Cheers.
Brian.
Thanks Brian,
Now I wonder what would happen if I replace my line with yours ![]()
Will check it tomorrow and report back
Stan
Hey Stan,
I will be interested to know the outcome, I backed up my entire flash to my PC before doing any mods, if you need a copy let me know, I am sure there is a way to get the file files to you.
My mods are limited to using GTI Matts Mods and to create my own colour scheme to make the UK minor roads more visible.
Cheers.
Brian.
Great stuff Brian,
I'm going to get mine done tomorrow as well, so far I only loaded Irish and UK maps on it, and I'm working on my own theme
I will copy the data.zip from my unit and play tiny bit with it.
Stan
Tried it today and it didn't work ![]()
Thanks for the feedback.
