71Nova said:...snip...Today I re did the grounds to the head unit and xm unit. 16ga ground wire about 8 in long bolted to a sanded shinny part of the firewall...snip...
The firewall isn't the best place to run a ground...especially a ground that is as important as this one is. With the issues you are having, I would buy a junction box, hook it to the firewall and hook your grounds to it. Then run the other side of the junction box directly to the battery...or where the negative cable hooks to the frame or block. You can buy a battery cable that has an aux lead to it you could attach it to. Experiment where you fasten that lead. If it is a ground issue, I'll bet that takes care of it. You are hearing feedback...probably from the alternator. You need to isolate that.
