Thanks for the post 1PACMAN, I've been pulling my hair out, I thought I must have installed or programmed the unit incorrectly. I re-programmed it 4 or 5 times, all with the same result. Here's the installation details.
- 2006 Ford Expedition.
- Pioneer AVIC-F90BT.
- Front controls install (white wire, version 3).
I have a couple of issues/frustrations to report:
1. It works intermittently, although it doesn't work more than it does. It seems to function OK just after I program it, but then it plain stops working again. I never know what I'll get each time I turn the engine on. The volume up/down is worse than the source/band selectors. Sometimes volume up will work but volume down will not. Sometimes volume won't work, I'll press the source button (successfully), then volume works again. Generally, source and preset work more often than volume.
2. As others have noted, the delay between a button press and the command being recognized at the head unit is irritating, especially when I'm not sure if the unit got the command or not (because of the intermittent issue). Before I know it, the speakers are blasting out, and volume down doesn't work!
3. I guess this may be the nature of the Expedition, but I can't have both the front and rear controls working, I have to choose which of them to hook the unit into. I can't even have two SWI-PS modules (one programmed for the front and another for the rear), because there's only one wired remote input at the head unit.
Should I return the unit to the dealer that I bought it from and eat the shipping and restocking charges? Do you have any updates as to whether there are plans for a more reliable version?
By the way, I called PAC this morning and was told that there are no known compatibility issues with the F90BT. I appreciate your post, it would probably be helpful to relay this information on to other callers.
