Hi, I've been browsing this forum for information and tips since I knew that I would get a F90BT ![]()
Received it, installed it. Works somehow well, but a few questions/issue have poped up:
1. Bypass
I have done the bypass via hardware. I've grounded the parking brake wire. It did not work with that alone. I then changed the yellow/black wire on connector AND grounded it. It worked one time for about 30min from my home to a friend's house. When I left my friend's house, I set the GPS to find another friend's house. After that, the bypass stopped working
It simply says that the PB wire is not well installed. I've verified twice and it is tapped onto the radio harness' ground wire.
FIXED using the software bypass
2. Contact voice dialing
The unit simply won't recognize any of my contacts ! I've transfered 83 contacts successfully. While some of them have special characters and are french name, I would have been okay with 30-40% of them not been recognize. But even names like Marc or Martin are not
I can use TTS for music control and even dial numbers. But no contact
Is there some sort of training to do ? I've tested all sort of combination:
Call Marc
Call Marc home
Call Marc at home
Call Marc mobile
etc..
Nothing works ![]()
3. Multiple calls
If I'm currently talking to someone and I get another phone call. The sound turns off and I have no control anymore. I must use my phone, and switch the source back to it in order to use it.
Setup:
F90BT 2.0.
Subaru Impreza WRX 07.
SD card 2GB with songs and videos always in.
iPhone 2.1 firwmare (not 3G).
Any help/tips would be appreciated ![]()
