Here it is at last. These image packs contain updated logo images and an ImageTbl.Dat file for all Sirius XM merger station changes including "The Best of Sirius". These logos were taken from the XM channel list PDF scalable vector graphic and exported with transparency to over 270 PNG files of dot-per-inch increments between 60 to 930 DPI. Each PNG was then color corrected to match the Pioneer color profile as closely as possible. A custom C# program scans these and creates AVIC sized PNG images in 56x24, 72x24, 90x30, 130x40, and 360x96 using the largest DPI logo that will fit for each channel. A second C# program then takes these PNG files and creates the specially formatted BMP and PIM files for each AVIC series in the appropriate sized and station ID filename and builds the ImageTbl.Dat. I will post the source code for these in the next week or so once the code is cleaned up and documented.
Notes and issues:
- The traffic and emergency channels will continue to use the original logo. There is no replacement for these.
- "XM Sports Guide" is not on the channel list PDF and thus has no logo.
- "xl Stars Too" is not on the channel list PDF and has no logo so I have assigned it the XM Sirius Stars logo for now.
- The "CNN Headline News" logo in the channel list PDF doesn't have the CNN logo on it so I did not include an updated logo for this channel. The original Pioneer version will apply.
- Sports Play-By-Play channels frequently change channel names depending on the broadcast and thus will only show a logo when the original channel name is in use. There is no workaround for this as the AVIC won't display logos unless the name in the ImageTbl.Dat matches exactly.
- A dozen or so logos, mostly the 136x40 sized, need minor touch with edges and small letters. I am still tweaking the program to try and deal with this.
- These packs will have to be updated again for the January station changes. "The Bridge", "Boneyard", and "Cinemagic" are supposed to be start or resume broadcast in January and until then I do not have the station ID to code them into the ImageTbl.dat.
- The categories portion of the ImageTbl.Dat is different between each AVIC series. Unexpected results might occur if you try to use the wrong one for a particular AVIC model.
Installing:
- As always when doing such updates make backups of your XMDAT, XMLPS, and XMDPS directories.
- Do not erase the existing logos. You will still need the Pioneer traffic, emergency, and CNN Headline News logos.
- Simply copy the files in the pack over any existing files for each directory (XMLPS, XMDPS, and XMDAT). The location of these directories differ by series.
First up is Z series. These have been fully tested on a Z3. The Z uses 56x24 images with a 224, 232, 240 (28, 29, 30 in 5 bit) background and 136x40 images with a black background in 16-bit R5G5B5 BMP format padded to the nearest 4 byte boundry. Because black is transparent on the Z all pure black colors have been adjusted up slightly to compensate.
THIS UPDATE HAS BEEN REMOVED. THE NEWER UPDATE IS HERE:
