heh killed my avic
By todx · Dec 02, 2008in Problems/Troubleshooting💬 26 posts👁️ 3,382 views
Page 1 of 2
Posted Dec 02, 2008 · 02:51 UTC#1
so i finally got my phone working and fixed my backup camera problem (bad ground) on my 700. i was putting my avic back into place and i hear a "pop" sound (wires prob got jumbled or something. i knew i was probably screwed. so i checked the fuse hoping it was broken and it looked fine. great. am i screwed? is it worth even returning to pioneer or just better to just get a new one?
to clarify it doesn't power on at all. i wonder if its just a bad power supply. im going to do some troubleshooting to make sure its getting power and what not.
thanks for any assistance you can provide.
Posted Dec 02, 2008 · 02:54 UTC#2
Did you check your other fuses in your fuse pannel ?
Posted Dec 02, 2008 · 02:56 UTC#3
no i will do that but the pop sounded like it came from the unit area. thanks for the suggestion. i did t splice into the power for my backup cam but don't think that was it since i didn't even power it on when it popped.
Posted Dec 02, 2008 · 03:59 UTC#4
:roll: If you have a bad install check all your wires and fuses in your car. If you pushed on wires and heard the pop it sounds like you had a live wire touch ground.
I would send it back to pioneer and see if they could fix it under warranty.
Posted Dec 02, 2008 · 04:14 UTC#5
i think i know what i did. im dumb. i forgot to put electrical tape around one of my wire connectors. it probably did touch ground when i pushed it back in. i wonder if i fried my camera as well which was also attached. so in doing that, im assuming a number of internals could have been damaged? or is it likely to be one internal component, such as a power supply, etc? i bought this unit on ebay refurbished so i believe it is supposed to have a 2 month warranty which i would fall under but don't know since i don't believe the place was an authorized reseller. if i do have to pay i wonder if its worth just buying a new one for 300 after cashback.
thanks for any input. im mad at myself now.
Posted Dec 02, 2008 · 04:28 UTC#6
you could get a new 700 for $236 if you get it before midnight with 10% ebay coupon and 30% live... then again you may have blown a car fuse... best bet would be to remove radio and power directly with car battery and see if it comes on.
Posted Dec 02, 2008 · 05:34 UTC#7
I agree, he probably just blew a fuse, I bet the unit is ok.
Posted Dec 02, 2008 · 05:50 UTC#8
unfortunately i didn't get a 10 percent coupon.
i tried testing the fuse with a multimeter on the unit and the radio fuse. its been a while since i messed with them but at the lowest ohms level it starts high and goes down to 0.1. From what I gather it should be okay?
the fuses seem to look undamaged (which i know isn't a surefire way of telling if its bad).
i appreciate anyones time. im going to pick up some fuses tomorrow. i hope as an added bonus to this situation i also broke my camera. i at least got to see it work for 3 seconds.
Posted Dec 02, 2008 · 06:34 UTC#9
dude, look at the fuse, if the little wire is cut/black then it's blown... you'll know if its blown, plastic will also be black also did you check car fuses?
if fuses are fine then;
take the unit out disconnect the car harness, take the red and yellow cables twine them together and then the black cable and connect it to the car battery terminals... the unit should boot up if it is ok.
If it doesnt boot up;
Try warranty... if you cant get warranty, get a new one then swap out s/n stickers and return (not recommending... but worth a try if you have to)
Posted Dec 02, 2008 · 07:02 UTC#10
take the unit out disconnect the car harness, take the black and yellow cables twine them together and then the red cable and connect it to the car battery terminals... the unit should boot up if it is ok.
Don't you have that wrong ? You want to tie the yellow and red wires together (not yellow and black like you stated) and connect them to the + side of the battery, then connect the black to the - side.
Posted Dec 02, 2008 · 07:22 UTC#11
aye, that is correct... nothing would've happened... but you are correct.
Posted Dec 02, 2008 · 14:10 UTC#12
If not a nav fuse, then a vehicle fuse from the system you are taking power from. If this was installed without any fuse protection, somebody should have their ass kicked
Posted Dec 03, 2008 · 13:53 UTC#13
get your voltmeter out, put it on the diode setting and start checking fuses the right way
when you're done, start checking power sources with the car on and off
if it still doesnt work, you've probably blown the pica fuse and its a real bitch to replace.
Posted Dec 03, 2008 · 15:45 UTC#14
i replaced both the avic fuse and my vehicle fuse and it was a no go. i am going to simply put a different head unit in to make triple sure that it's getting power.
I called pioneer, and they said that anything purchased on ebay is not covered by their warranty, since they consider ebay to be the seller (not the ebay seller itself) which is not an authorized dealer.
the one time repair fee for what seems like any problem is $200 (unless there is something drastically wrong with it). i told them i wasn't going to send it in.
if i am getting power, i will probably start taking it apart or have a local repairman try to fix it. if that doesn't work ill probably just get a new unit. is that fuse you talk about terron inside the unit? why do you say it is a bitch to replace?
again, thanks for all help.
Posted Dec 03, 2008 · 16:00 UTC#15
FYI, I bought my 90 on eBay and had no problem getting warranty service. I didn't ask customer service - I just sent it in with a letter telling them what I needed (reflash in my case), included a copy of my PayPal receipt and got the unit back via UPS (they even paid the postage, had repacked it and even did the 2.0 upgrade) about 10 days after I sent it... This was about a month ago...
Posted Dec 03, 2008 · 16:12 UTC#16
that's pretty cool. i think at the level of my problem though they would require proof...at least that is what im telling myself since i already gave them my serial number etc and they probably already have record of it being on ebay.
Posted Dec 03, 2008 · 21:54 UTC#17
so a search for "pica fuse"
its tiny and rather difficult to get a solder iron tip in to unsolder and replace with a wire. not saying this is the problem, but its another fuse inside the unit that isnt user friendly serviceable.
Posted Dec 06, 2008 · 00:57 UTC#18
well i got good news. well good news for me at least most of you probably don't give a shit but regardless....
i hooked up another head unit today to my vehicle and it also did not turn on. hmm. having being sick of hooking up wires, splicing, etc, i decided to stop being a pussy and hook up my avic directly to the car battery as two of you had recommended. sure enough the thing booted!
so now i just have to figure out if one of my connections to the vehicle wiring harness was bad which is the likely case. could it be possible that my boyo camera which i tapped into the +12 volts to the head unit was preventing enough power from powering the head unit? im not going to try to hook it back up till tomorrow because im sick of installing and need to get drunk but...have any of you also tapped your camera into your unit power sucessfully? it was either that or a bad connection or i guess the least possible cause (and most painful) would be some type of problem from my vehicle wiring harness to the battery (yes fuses are fine).
so to sum up this long and verbose post, you all have success powering your cam by tapping into the head units power?
thank you all again.
Posted Dec 06, 2008 · 01:14 UTC#19
Yep, I tapped into the same power to my head unit for the backup cam with no problems. Glad your head unit is ok. I figured it was. You could just tap into a fuse from your fuse pannel and run a new power supply from there.
Posted Dec 06, 2008 · 04:39 UTC#20
I would still bet that you blew a fuse. I don't know what kind of car you have, but many cars now have several fuse boxes. Mine has one in the trunk, one (or is that two) under the hood, and one hidden behind a kick panel. Are you sure you have checked all fuse locations?
Posted Dec 06, 2008 · 05:43 UTC#21
I agree it's probably still a fuse. The small knife fuses can be deceiving. I've had them where they look ok, but after checking them with a meter they were actually bad. I'd recommend you check them that way.
Posted Dec 06, 2008 · 07:15 UTC#22
Year, make and model of car please.
Posted Dec 06, 2008 · 12:50 UTC#23
I can almost ASSURE you..its simply a blown fuse. Take the effort to remove each and every fuse, visually inspect each one, then reinsert or replace as needed. This is what fuses are for...to protect circuits. And this should also be a lesson to solder wires together properly, then shrink wrap the connections WELL.
Posted Dec 06, 2008 · 15:18 UTC#24
could be another fuse i don't know about. ill do some research. its a 2008 nissan frontier.
Posted Dec 06, 2008 · 17:42 UTC#25
Fuse 29 under the hood, right rear of engine bay.
Page 1 of 2
