Hi all! I thought I'd share my F90BT installation with everyone. Below is a list of my goals going into the project, with my overall reaction to the F90BT at the bottom. Thanks to my good friend Bill for installing this in 1/100th the time it would've taken me!
System Goals:
- [*:pgfa8vt1]Upgrade factory head unit with in-dash navigation/bluetooth/Ipod control[*:pgfa8vt1]Upgrade front soundstage utilizing factory speaker location[*:pgfa8vt1]Add an SQ subwoofer in the rear hatch[*:pgfa8vt1]Retain stock look and 100% functionality of hatch area
Here's the bill of goods going into the new system:
- [*:pgfa8vt1]Head Unit: Pioneer AVIC-F90BT[*:pgfa8vt1]Front Stage: Boston Acoustics Pro 6.53 three-way component speakers[*:pgfa8vt1]Rear Stage: Eliminated[*:pgfa8vt1]Subwoofer: JL Audio 13TW5-3[*:pgfa8vt1]Front Stage Amplification: JL Audio 300/2 v2[*:pgfa8vt1]Subwoofer Amplfication: JL Audio 500/1 v2[*:pgfa8vt1]Sound Dampening: Cascade Audio (various products)
Starting off in the front of the car.
2AWG power cable & fuse holder. Using stock battery for now:
Wiring speaker cable through te molex into the doors. Power wire was run on the driver's side of the car:
Sound deadening and speakers installed in/on doors:
Backside of door panel (deadening was installed here too):
Picture of dash vent (pic borrowed from vwvortex.com):
Dash vent removed for installation of GPS antenna. You can see the black antenna towards the center of the photo:
Whole mess of PAC adapters for steering wheel control, etc.:
Bluetooth mic installed in factory location (sounds great):
And finally, the deck permanently installed:
Now onto the rear of the car!
Here's the hatch with everything removed. Notice the gigantic hump VW decided to put in the middle of the spare tire well. This had a large impact over what I ended up using for the sub.
Creating the sub box, amp & crossover mounts, as well as the cover for all the equipment.
All the mounting platforms & sub box installed.
Pics of the mockup and installation of the components:
Finished hatch with cover installed:
And with the factory trunk liner on, it looks 100% stock!
Overall impressions/thoughts
The F90-BT is a pretty versatile unit. I'd consider it a jack-of-all-trades, but master of none. After installing the 2.0 update, removing key beeps, adding a nav mute button, and performing the hardware bypass I feel like the unit does everything I expected it to.
The iPod interface is excellent, and a MILLION times better than the standard VW interface. I've had no dropout issues so far. Bluetooth is also very good; my iPhone 3g synched up immediately and contact transfer was painless. My reception is very good as well.
AM/FM reception is also improved with this unit, and other inputs (CD, iPod) sound better than stock as well. Overall sound quality of the unit is decent, but not exceptional. I knew there would be a tradeoff getting so many features in one unit; in this case overall sound quality isn't as good as some audio-only decks I've used in the past. But the breadth of features outweighs the slight deficiency in audio performance.
