is this my parking brake wire
By shaft412412 · Dec 07, 2008in Hacks/Mods💬 7 posts👁️ 1,553 views
Posted Dec 07, 2008 · 22:29 UTC#1
Is this the parking brake wire i need to ground. Its the lightest green colored wire that is going into the black connector. I dont know how to add pictures to this so would anyone with knowledge of this let me email the picture that i have of the wires. thank you[/img]
Posted Dec 08, 2008 · 01:27 UTC#3
the parking brake is the only green wire in the harnass to my knowledge, so yes, that is the one you need to ground
Posted Dec 08, 2008 · 01:43 UTC#4
also i'm trying to ground the parking brake wire after best buy installed it and said no they couldnt ground it for me. So the green wire that i found ( that i assume is the parking brake wire) has been installed deep into my dash along side a pink wire. does this change what i need to do?
Posted Dec 08, 2008 · 11:47 UTC#5
Nope
snip the green wire about 8 inches from the radio, solder (or use the connector pictured below) the end still attached to the radio to the ground cable. If you don't have a soldering iron, use this:
This alone will not work for the hardware or software bypass. If hardware, you need to ground another wire and all that can be read in the thread in this forum. If software, you have some config files to change.
By the way, tape up the other green end now hanging loose so you don't blow something up
Posted Dec 10, 2008 · 20:49 UTC#6
I got the parking wire grounded and i also tried to move the mute wire. After the best buy install, the mute wire was connected to a brown wire. I undid this and ground the mute wire. I covered up the remaining brown wire. not sure if i did everything correctly but for the parking wire is grounded. My only problem now is, my ipod makes sounds like a CD skipping. Does this have to do with my mute wire at all. I have checked and rechecked everything for the ipod but it still makes the noise. Its only the ipod too, not anything on the radio. any suggestions?
Posted Jan 08, 2009 · 02:53 UTC#7
I hope you moved the pin in the harness for the mute wire to the correct spot as well. Not sure what would cause a cd skipping sound. I might look to make sure that there are no wires touching the fan in the back of the unit.
