F90Bt keeps resetting
By bigrick · Dec 08, 2008in Problems/Troubleshooting💬 10 posts👁️ 1,648 views
Posted Dec 08, 2008 · 02:43 UTC#1
ok this just started yesterday and i have only had my unit for a little over a month. after 2 minutes of turning on the unit it resets itself over and over again anyone know anything i can do or do i need to ship it back to pioneer?
Posted Dec 08, 2008 · 13:10 UTC#3
so just to get this right im going to completly delete everything in the my flash drive and then insert the sd card with the 2.0 update and it will then update with a new my flash drive file. do i delete the whole flash drive or just the files in it?
Posted Dec 08, 2008 · 14:01 UTC#4
Did you do any modifications/hacks? Do you have a backup of the flash drive in its original form?
Posted Dec 08, 2008 · 23:32 UTC#6
does anyone have a copy of the original flash drive i never made a copy of the entire file
Posted Dec 09, 2008 · 00:14 UTC#7
I do, I have no idea if it is too big to upload here though (it is 1.64 GB).
Posted Dec 09, 2008 · 02:09 UTC#8
Tried to upload it, it wouldn't...too big I guess
Posted Dec 11, 2008 · 14:44 UTC#9
i figured out the problem. i unpugged the gps antenna and everything worked fine, but this is far from a solution so ill be returning it to pioneer
