Moved from D3 to 900bt got questions
By fudd · Dec 10, 2008in General💬 6 posts👁️ 841 views
Posted Dec 10, 2008 · 21:20 UTC#1
Hi,
I recently purchased the 900bt. I have installed the D3 in my FJ, bypassed etc. I wanted to know if I need to replace all the wiring already in place or is there some long shot that its the same wiring for both? and I can just plug in the 900bt. I did purchase the iPod cable and mostly use my iPod in the vehicle, I have been frustrated with the iPod interface in the D3 and am hoping the 900 is an improvement.
Thanks in advance
Posted Dec 10, 2008 · 23:14 UTC#2
others have reported its the same harnass
ipod is better than the D3 but it has some hiccups
Posted Dec 10, 2008 · 23:52 UTC#3
Yep, they're the same harnesses, however the mute wire needs to be relocated for the bypass because it needs to be in a different location on the 900
Posted Dec 11, 2008 · 03:10 UTC#4
Same as the others have said. The voice recognition is great for accessing the albums and artists on the Ipod. AND the F series has working menu tabs for artist/genre/album, etc. AND the f series allows you to quickly access a letter of the alhpabet, touch that letter, then see all of the artists that start with that letter. Far improvement over the D3. And (assuming you have a compatible Ipod) you can access your videos on the Ipod, from the F series now..instead of having to grab the ipod to start videos with the D3
Posted Dec 11, 2008 · 03:41 UTC#5
Thanks guys appreciate the input. I'll look around the forum for how to relocate the mute bypass. I'll let you know how it goes.
