Cadillac Escalade 2004 Stock CD Changer
By codom2000 · Dec 26, 2008in General💬 32 posts👁️ 7,108 views
Page 2 of 2
Posted Dec 31, 2008 · 16:15 UTC#26
funny because @ the meetings they said no.
then the little japanese man from pioneer said no when he was here..
i'm very interested in seeing this work myself...i might have to plug one up to my display and see.
EDIT: CDX-P686 plugged into an F700bt and no bueno.
Posted Dec 31, 2008 · 23:53 UTC#27
And lets face the fact that this guy has no pictures, he went and tried to install it and found out he was wrong.
Thats the thing about pride; your mouth starts writing checks you can't possibly cash.
Posted Mar 31, 2009 · 01:32 UTC#28
I connected mine to the D3 (xdv-p6) , how do you get it to select play on the DVD menu ? Mine is mounted in the trunk are.
Posted Jun 11, 2010 · 17:08 UTC#29
Sorry to bump this. Was an actual workaround, adapter or software update ever released allowing this to work?
Posted Jun 11, 2010 · 18:19 UTC#30
No.
Posted Mar 09, 2011 · 23:49 UTC#31
I have an 06 Sierra Denali with the stock 6 disc changer. I was wondering if it will work with the AVIC-Z120BT? Also is there any way to retain the rear seat entertainment which included an overhead dvd player and wireless headphones. Also have the back seat audio controls on the back of the console. I know the onstar, bose, steering wheel controls, and xm radio will work with the right harness but not sure about the others. Any help would be much appreciated.
Posted Mar 17, 2011 · 15:16 UTC#32
all right, we'll say this for the last time, no one will ever get a factory CD changer, to work with an aftermarket headunit, plain and simple. do you really think that your cd changer in your 06 sierra (full size chevy) is really much different than an 04 esclade (full size chevy)or have you not really been reading the whole thread.
you can also kiss the rear seat controls good by, i have got a few to work with aftermarket radios, but it had to use the steering wheel controls input (meaning that you can not also have the steering wheel controls working at the same time) its one or the other.
now you actually have some good news, with most of the chevy overheads its pretty simple to retain them, especially if it is one of the Panasonic built units.
for this you will need to run a set of AV cables back to the over head system from the AVIC's AV out plugs, then you will need to disassamble the over head and find the AV inputs, cut the wires running to the back of the board with the RCA connectors and cut off the ends of the newely ran RCA cables and then solder them together (if you dont know how to do this, then take it to someone that does)
also with most of the chevys i have done, you can run another set of RCA's from the overhead back up to the AVIC's AV input and tap into the video lines comming out the the factory DVD player as it goes into the monitor so that somebody can also use the rear DVD player and you can select it as a source from the front and watch it up there.
there you go, now you can control a video for the kids in the back, or let the adults in the back handle playing a movie for you.
Page 2 of 2
