Ipod Album Artwork..
By Clo · Dec 31, 2008in General💬 18 posts👁️ 2,617 views
Posted Dec 31, 2008 · 03:37 UTC#1
I have only had my F900 for a week or so now and I have noticed the album artwork from my ipod when small is OK at best and when I maximize it, it is horrible.. it is very distorted and I can barely make out the picture. How could I fix this..
And I have tried to search but gave up after a while of looking..
Thank you in advance
Posted Dec 31, 2008 · 03:59 UTC#2
Be sure to download quality pictures of the album art. Low / poor resolution will give bad results. If it looks bad on your PC it is going to look bad on the screen output when enlarged. I do not use iTunes for the art. I search the web for the album cover and save to my picture file. Then I manually input the pictures using a right click on the selected song / title using "get info" to add the art and then repeat until all songs have the same cover for the album. Once you start the process where is an option to go to the next song and add the cover again until all are done.
So far it has worked great. I am using an iPod Classic so not sure how this would work out with other versions but assuming it would be the same process.
Posted Dec 31, 2008 · 04:10 UTC#3
That's weird because I have what I think are great pics for album artwork, I have gone through and googled most of the pics and they look good on my comp.. and Ive tried it on my old ipod nano and a new ipod touch, same outcome..
I will try it again thank you for your help!
Posted Dec 31, 2008 · 04:23 UTC#4
That is odd, hope this works for you. I do get a bad pic every so often but can see it easily when I bring it up in full screen while in iTunes.
Good luck with it and wish I had more options to offer
Posted Dec 31, 2008 · 04:27 UTC#5
Damn, haha I was hoping there was a resolution button I could just hit and it would all work out.. well thanks for your input it is greatly appreciated..
Posted Dec 31, 2008 · 05:28 UTC#6
This is a known issue with the F series. There is a lengthy thread discussing this very issue. You can search for it. The short answer is that its random across the ipod generations. Some people say it works perfectly, others have blurry album art on the F when it's perfectly clear on their ipods (myself included).
Posted Dec 31, 2008 · 05:55 UTC#7
I have done a search and cant seem to find it??
Do u know what I would search for, blurry artwork, Ipod artwork, artwork,??
Just looking for a direction,
but thank you for ur help, ill keep looking..
Posted Dec 31, 2008 · 06:09 UTC#9
my man thank you..
Posted Dec 31, 2008 · 06:25 UTC#10
No problem man. 8)
Posted Dec 31, 2008 · 11:38 UTC#11
I've got an 80Gb Classic and have no problems at all with the artwork. 99% of my artwork was obtained from either allmusic.com or Rhapsody.
Posted Dec 31, 2008 · 12:36 UTC#12
I think a lot of people are confsued what were discussing here, push on the art work picture when displaying the ipod source. It looks great small, as a thumbnail, but when you go to enlarge it as stated above, it comes up in a very magnified distored mess.
When you do push on it, it enlarges to overlay/coverup the time played and artist/song/album information. this i the only time its blurry like this, which says the unit samples it at a certain resolution, then when enlarged instad of resizing it to fill the screen at high resolution it simply zooms in at the same resolution, making a nasty distorted picutre, sort of like zooming in to a very low resolution gif.
Hope this is info is helpful.
Posted Dec 31, 2008 · 15:45 UTC#13
This comment is based on what I've seen here and other forums, and has no implied voice of authority at all.
It seems like the iPhones and the iPod touch are more likely to exhibit this, and the older classics less likely.
My suspicion is that *all* units can have poor quality artwork that you don't notice in thumbnail, and that lousy artwork will always look bad expanded.
However the way iphones and ipod touch units handle artwork means that they tend to output a bad version of good art more often.
As opposed to the older classics (and much older) that when they have good artwork, then pass good artwork..
What's everyone think of this?
Diane
Posted Dec 31, 2008 · 16:33 UTC#14
Sounds reasonable, Diane. All I know is that with my Classic, my artwork is flawless, whether it's the thumbnail or the larger view. More than likely, I would think this may be a case of garbage in/garbage out. Unless of course the touches and phones are trashing the graphics.
Posted Dec 31, 2008 · 16:55 UTC#15
When you say Classic Ipod what are your refearing to, 1st gen Ipods, or what? Because I have tried,
Old 2gb Ipod Nano..
1st gen ipod touch..
1st gen iphone..
Brand new Iphone 3g..
Brand new ipod touch..
and the art work is crappy with all of them.
So I was just wondering what "classic meant" how old do I have to go?
Posted Dec 31, 2008 · 17:35 UTC#16
Almost without exception, my album art on my Mac looks great. There is the odd one or two albums that I cannot find a decent image for, and those a re a lot more pixelated.
That said, they ALL look pretty lousy on the F90. A lot worse than they do at what ever size I could see them on the Mac itself.
I am of the opinion that it something to do with the way the software of the F90 is "reading" those files. The reason I say this is because the image I used for my Splashscreen looks great. All the art files for the iPod, not anywhere near as good.
Do I wish they looked better? Yep. I just don't have the knowledge to fix it at this point. Something is better than nothing at this point, I guess.
My OEM head unit sure didn't show album art! :D
Cheers,
Kev
Posted Dec 31, 2008 · 17:40 UTC#17
Old 2gb Ipod Nano..
1st gen iphone..
classic = ipods with hard drives, and all older then the units you list that are solid state.
If you notice.. all but one of your units is based around the new "touch interface" that I suspect is the more likely to hand out bad art.
Also pay attention that I said any unit, no matter what age, has the potential to show bad art if that's all it has, and you'd never know it on the ipod screen itself since they're so small.
Diane
Posted Dec 31, 2008 · 21:22 UTC#18
Gotcha, thanx again Diane, Always there to help..
