HELP!!! AVIC-F700BT Doesn't power off
By Cmacrae · Jan 03, 2009in Problems/Troubleshooting💬 3 posts👁️ 661 views
Posted Jan 03, 2009 · 02:47 UTC#1
Installed in a 2002 jetta but doesn't shut off when car is powered off and key is out. Any ideas?
Posted Jan 03, 2009 · 10:25 UTC#2
See here...
http://www.avic411.com/forum/viewtopic.php?t=20542
Does a 2002 Jetta have an ISO connection or is it quadlock?
Its becuase you have taken the factory radio out and that has the can-bus built in.
The Pioneer is getting a live feed from the yellow wire and red wire. The red wire is the ACC switch.
You need to tap into the ignition switch or the way i did it was find a pin on the VW harness that the ignition controls and use that.
The better way would be to install a can-bus adapter and this will give you switched ignition as well as speed sensor, reverse and illumniation.
Let me know what conection you have
Posted Jan 03, 2009 · 22:53 UTC#3
This worked! Thank you!!!
