AVIC-F 700 Voice Control Problem.
By Mcrone86 · Jan 05, 2009in Problems/Troubleshooting💬 18 posts👁️ 2,939 views
Posted Jan 05, 2009 · 21:42 UTC#1
I just put the AVIC-F 700 into my 2007 Chevy Avalanche and everything works great, except that when I try to use voice controls for my iPod or my cell phone I get nothing, all it does it mute the system when I press the button. I tried to find a post on this, but I didn't see anyone else with the same problem... I've also been reading the manual it came with and I see no troubleshooting info for that in there either.
If anyone could help me out that would be great!!!
Thank You!
~Michael
Posted Jan 05, 2009 · 21:47 UTC#2
Dumb question,
Is the microphone hooked up?
Posted Jan 05, 2009 · 21:49 UTC#3
yes it is, I can make calls just fine using the phone or going threw the system to make a call, I just cant press the button to do anything, it worked fine before I put the system in, like I tested it all before I screwed it in. but now pressing the button does noting sept mute it.
Posted Jan 05, 2009 · 22:19 UTC#4
Pressing and holding the button in does cause the unit to mute. This seems to be the way it is supposed to work. Pressing briefly and releasing the button triggers the VR. I have found that it may or may not respond if I try it the first few minutes after start-up. After that, it is usually okay. (There can still be a variable delay before it prompts for a voice command.)
Posted Jan 05, 2009 · 22:28 UTC#5
I agree it usually takes a min or so to work, but I left the car running in my driveway for a good 15 min to see if that was the problem and it still failed to have the lil blue screen pop up. I did read in the manual that if you hold the button long enough it's supposed to mute the system, but I've tried just about everything I could to get the voice command screen to pop back up and I get nothing.
~Michael
Posted Jan 06, 2009 · 18:34 UTC#6
by Any Chance would it have to do with the PAC harness I used for the steering wheel? like could that be overriding the VR command for the whole system?
Posted Jan 08, 2009 · 18:38 UTC#7
Here's a thread from a while back http://avic411.com/forum/viewtopic.php?t=19182&postdays=0&postorder=asc&start=0 I've had the same problem. No idea what causes it and haven't found a fix yet. It hasn't bothered me all that much, just annoyed that it doesn't work. Finally have some free time though, so I may give support a call and see what's up.
Posted Jan 09, 2009 · 06:29 UTC#8
I think the problem is with the blutooth overriding it. today Iw as messing around in my truck and didn't have my iPhone with me and I pressed the button and all the sudden it worked. but as soon as the system aired with my cell, it stopped working again, which is total bs cuz isn't that the whole point to be able to use VR with the cell???
Anyway, I think I'm going to take it apart sometime tomorrow see if there is anything I can fix with it.
Posted Jan 09, 2009 · 13:55 UTC#9
Have you tried deleting your phone's profile and pairing again? Might save you the hassle of ripping open the dash.
Posted Jan 09, 2009 · 14:04 UTC#10
What would opening the unit have to do with a software issue?
Posted Jan 09, 2009 · 21:06 UTC#11
I have no idea, I had to take it apart anyway to fix the steering wheel controls anyway...
yes, I have tried deleting and reparing it and still I get nothing. it's such a pain.
I don't know what else to try.
Posted Jan 10, 2009 · 23:27 UTC#12
Just so you know, you can only activate the voice recognition from the map screen or the AV screen. Try this and see if it works.
Thank You!
~Michael
Posted Jan 12, 2009 · 23:56 UTC#13
have you tried pairing a different phone to see if the results are the same? have you tried not pairing the phone, pressing the vr button, then try pairing your phone after the vr button works to see if that does? just suggesting some troubleshooting tips.
Posted Jan 13, 2009 · 18:23 UTC#14
I found out last night that if I don't pair my cell that I can use VR for the iPod and radio but as soon as my phone comes close enough to get paired to the system the VR stops working, I've tried to pair different phones, and I've unpaired and re-paired phones a billion times and I still can't seem to get the VR for the phone to work... which totally sucks cuz that was like one of the biggest selling points to get me to buy this system.
Posted Jan 13, 2009 · 21:50 UTC#15
Have you tried it without transferring your phone book? Have you looked at the resulting database file to make sure there are no non-alpha characters in any of the names?
Posted Jan 16, 2009 · 00:40 UTC#16
I deleted my phone's connection in the f90 and turned off bluetooth. Turned the unit back on and the VR button still doesn't work. It seems that it has to be some strange software bug (shocker) because I can mute the system fine.
Posted Mar 07, 2009 · 05:55 UTC#17
I have noticed that my voice command only access in specific screens. If I'm on the menu screen, I cannot activate voice command. If I'm on the map or on the active AV source screen, the voice command works.
I wonder if this is by design or chance?
Posted Mar 08, 2009 · 22:10 UTC#18
That's by design. You can only access it from a few specific screens.
