I don't think this works, also I'm a bit confused.
Gamezilla said:
I just thought of a better idea of how to unlock the hard drive.
If you have a laptop, then theoretically you will be able to do this.
I'm not sure why a laptop is necessary for this....
Gamezilla said:
I have one of these, they are very useful, but I don't think this will work.
Gamezilla said:
1. power up your z1, and wait like a couple of minutes to make sure its fully booted up.
2. take out the hard drive, but dont discconnect the power cable, ONLY disconnect the data cable.
You want to pull the drive out of the Z1?
Well first things, the drive is enclosed into the housing, you pull it all out. I don't think I would recommend yanking out the drive while the unit is running. I don't think that's too safe. Also, laptop drive's power and data are all on the same cable, so even if the z1's connection was a cable and it would extend, you had to pull the power and data off at the same time. And most laptop drive "recepticals" are not cables, but are just pins on a board. As soon as you pull the Z1's drive out 1/4 of an inch (to expose just a small part of it) the power and data connection is disconnected.
I still wouldn't pull the drive out of the Z1 while it was running.
Gamezilla said:
3. then using the cable from newegg that i posted above, connect the hard drive to your laptop.
now the hard drive should be fully unlocked, and all you gotta do now is use one of those programs that someone else mentioned to prevent it from locking again.
so could somebody please verify if this could be done?
This hot swapping technique is not something I would recommend. Even if it was possible that it might work, I wouldn't do it. For the $50 to unlock it safely like the rest of us have done and know that it's safe, I would do that.
