Leetlauncher 2.0 + Miopocket unlock for AVIC F series
By xdanx · Feb 09, 2009in Hacks/Mods💬 91 posts👁️ 37,841 views
Page 2 of 4
Posted Feb 14, 2009 · 23:43 UTC#26
Hmm, not used to uploading pics, maybe this will be better....
Posted Feb 14, 2009 · 23:51 UTC#27
Lookin good..........
Posted Feb 15, 2009 · 03:24 UTC#28
Ok, one last attempt and then I will give up and assume that this is something that only works on the 500's.
I start the system with the SD card inserted and all of the files exactly as shown.
The Mio Installation menu starts installing all of the parts to the program.
On the very last line of the installation it says, " Installation Complete... Rebooting"
And then the entire system reboots and starts the process over.
Am I to do something else? Do I initiate the program from within testmode?
Or should it just open and begin working after the installation is complete?
Thanks for any help you can offer...
T
Posted Feb 15, 2009 · 13:09 UTC#29
WOOHOO!
I'm in, Fred :D
Turns out re-named (Mio) CopyTool.exe was actually named CopyTool.exe.exe (????????). Dunno how this happened, pretty sure it wasn't me that did it, so maybe Carlsbad should check his file names too.
Now to see if I can get it full-screen: it started up in 'Stopword' skin @ 480 X 260 (at least I think I think that's the res.).
Will post soon with any info I have.
And thanks once again Fred for your help on this :wink:
You're welcome. I'm glad you've got it working. I was puzzled why it didn't work because all the files seemed right. The double .exe explains it all.
You can easily change the skin in MioPocket. Just run Skin Changer, select "more skins" and select Vista Ultimate 800x480.
@carlsbad0331:
It seems like MioPocket doesn't run on your device. After reboot MioPocket should start automaticaly.
Posted Feb 15, 2009 · 15:06 UTC#30
That's awesome. Only question I have is why can't this be done on the 700, 900, or 90?
Posted Feb 15, 2009 · 15:50 UTC#31
I dont get it either... I thought we had confirmed that the same software was used for all of the F series units.
Oh well...
Posted Feb 15, 2009 · 16:09 UTC#32
I don't see why it wouldn't load on the in-dash units. I followed the renaming and placing of the exe files as was explained earlier in this thread. Loaded the first time.
I don't think I'll use it at all. Unless I did not do it right, I find it pretty useless. Others may have better results or have use of what's included. I'm just giving my opinion.
I directed the IGO link to ezrider.exe and it connected but the map, menu and knob buttons were not operable. Often times when clicking on a program and exiting it, the next time I tried to open another program it would not initialize it saying the link could not be found. If I were to remove the SD card and put it back without exiting it would find the link. Some of the games require a gapi driver that's not on the unit, but there are about 40 others. Tried most of them for compatibility with no luck.
The 800x480 theme would not load for me at all.
Posted Feb 16, 2009 · 21:08 UTC#33
Yeah, it's the same for me, buttons inoperable, although the 800 x 480 'Vista Ultimate' loaded no prob.
I would find this a great app. but only if I still had full functionality of the Avic - at the moment this isn't the case, but I'm delving deeper......
Posted Feb 16, 2009 · 21:53 UTC#34
Vista Ultimate 800 x 480
Posted Feb 26, 2009 · 21:21 UTC#35
With the help on another forum from the guy that produced this, I got it working on my 500. I think it may be a good set of app.s to use, similar to having your Avic combined with a PDA. The only prob is that Bluetooth is now lost (hopefully only temporarily), both in MioPocket and in Avic, with and without MP loaded. I'm gona try sort my BT probs, and will post when I get a result, although I'm not sure if anyone else is all that interested in running MioPocket.
Posted Feb 26, 2009 · 22:51 UTC#36
Let me know what guys modified to get it working right.
Were also able to solve the issue of the map, menu and zoom button not working when enabling the nav software from Mio-Pocket?
Posted Feb 26, 2009 · 23:05 UTC#37
OK, here's the state of play right now.
In MioPocket, when asked to provide executable path for iGo, intsead of ezrider.exe use MainMenu.exe
This then loads iGO and you can access it from MioPocket main screen.
It's a tad sluggish, but once back into iGO/Avic all the buttons work and the functionality is the same, at least as far as I have found up to now.
BUT, there is a drawback in as far as totally wiping out Bluetooth from the Avic. I'm in the process of trying to sort that now, will let you know how it goes. Any ideas on this will be appreciated............ :?
Posted Feb 26, 2009 · 23:11 UTC#38
Thanks. I'll see happens next week. Which bluetooth version are you running? I'm running the one from the US update HW100-SW330 RC3
Posted Feb 26, 2009 · 23:19 UTC#39
Mine was the same, but as I said it's totally gone from my 500 now, so I'm in the process of trying to re-install. Prob is I've not yet sussed where exactly it's disappeared from........ PFFFT
Posted Feb 27, 2009 · 01:09 UTC#40
im not sure how well this would work with our slow windows CE units, being that my freezes up every once in a while when I use the blue tooth phone.
putting this program into the Avic units may not be a good idea. Like giving a math equation to a blonde, its gonna freeze up.
Posted Feb 27, 2009 · 01:24 UTC#41
Last thing I'd think of giving a blonde is a math equation.......... :P
But on a serious note, after using MioPocket for a short time I must admit it's something I would like to use, so I'm gona try and get it working with my 500 and Bluetooth. Don't forget, Avic/Navi and MP will be running side by side and not together. Well, they will be running together, but only one will be in use at any time, not both, if you get my drift............?
Posted Feb 27, 2009 · 01:38 UTC#42
now im starting to feel like a blonde with an equation. but i think i follow you, kinda like having multiple windows minimized when watching porn, the two windows are running together but your only using one to watch the performance.
If you can make it work and integrate it flawlessly, then awesome. but it would be a pain in the as if it requires reset or test mode to boot into it. but yeah, it would be tight.
Posted Feb 27, 2009 · 02:16 UTC#43
It does require testmode (MioPocket, not Pioneer) to boot via SDC, but for me that's not a prob, I only use my headunit/cd changer for audio so SDC slot being taken up isn't a hassle. At the moment I know there's a few hurdles to overcome, but I'm gona try and get this fully working. Wish me luck........
BTW the guy that built this MioPocket is awesome, you should have a peek at the forum, you'd be amazed :)
Posted Mar 01, 2009 · 00:06 UTC#44
OK, I'm not yet knowledgable enough to sort this out on my own so I could do with some help.
I install MP on my 500, MP then prompts me to choose an executable for the path to iGo.
From the displayed list in MyFlashDisk I first tried APL/ezrider.exe but that didn't work so I tried others. The one that finally seemed to do the job was APL/MainMenu.exe. The buttons/menus/maps etc. all seem to work as they should (albeit a little slow), so happy days.
Only it's not happy days, coz I can't get BT to work, and when I go into
Avic > Phone Settings it informs me: Bluetooth Software Update > Version: > Not Found. So somehow BT has not been installed. At first I thought I would have to re-install BT back to Avic, but when I uninstalled MP from my 500 I saw the BT had returned. So I figure that BT had not disappeared in the first place, MP was simply not loading it, or was stopping it loading.
So I need help with getting either iGo or MP to load BT, either at or immediately after boot-up. Anyone that can point me in the right direction please feel free do so, I'm all ears/eyes.
Edit: Would anything regarding a Registry be of any use?????
Posted Mar 01, 2009 · 10:48 UTC#45
OK, so I've figured out inserting >MyFlashDisk/APL/Tel.exe< into >MP/MyApps/Progs< and BT now works but only when launched from >MP/MyApps/Tel<.
In >Avic/Phone Settings/Version< it says 'Not Found'.
So I now know BT is accesible, but how do I get it to run as it should, from start-up, ie: as it would normally on the Avic when it boots, and once again be functional in Avic operation - without having to revert back to MP and launch it from there?
Posted Mar 01, 2009 · 18:05 UTC#46
Hey Dumpy.
If my recollection is correct, I believe the MioMap program has some sort BT app built in. I wonder if you disable the BT app in MioMap if it'll solve the issue.
Posted Mar 07, 2009 · 07:32 UTC#47
Does this work with f700bt?
Posted Mar 07, 2009 · 07:39 UTC#48
Try to put tel.exe in the startup folder.
Posted Mar 09, 2009 · 03:21 UTC#49
N-S-E-W and Carlsbad,
Any luck with the new files I just posted on the first page?
Posted Mar 09, 2009 · 03:36 UTC#50
Actually dumpy has been more active in trying to get it to all work. I spent some today trying to see if there was an easy way to stop the BT in MioPocket from loading but I did not have any luck in finding an easy fix. My guess it's built into one of the executable files. It's my belief that the BT in the Pioneer is conflicting with the BT in MioPocket. Dumpy has been communicating with the person who created MioPocket so I'll wait it out to see if he has any luck.
I didn't try rev 42 since osprey mentioned the revision had only minor fixes. I also don't want to put myself through what dumpy went through when his BT got disabled.
We do know that it loads on 500, just not very useful at the moment. When it does work I don't envision myself using it much. It is intriguing though.
Page 2 of 4
