Need Help Themes
By swankydank2001 · Feb 17, 2009in Hacks/Mods💬 4 posts👁️ 1,040 views
Posted Feb 17, 2009 · 21:07 UTC#1
Hey guys ive done some mods to my system and was wondering how do i make my own theme. Ive seen threads but have not come across any that gives you step by step.
Ive found the res folder. what are the size of the main icons and then the menu icons.
Posted Feb 18, 2009 · 02:52 UTC#2
Swan,
It's not really that easy to do it..You'll need to extract the contents of the image.res and edit all the icons you want.
Make sure they are in BMP windows format otherwise the unit won't read them.
After changing everything you want just zip it bakt using a software called 7zp (google for it) and compress it as a .7zp file, change the extensio to .res and copy it back to the unit...
Here's a them that I did....
http://www.avic411.com/forum/viewtopic.php?t=21840
Maybe it's a good start.
GUGA
Posted Feb 18, 2009 · 08:00 UTC#3
Swan,
GUGA
ggarcez..........
ok last questi0on what program do u use to edit ur images, Im trying to do an Impala symbol over certain icons.
Posted Feb 18, 2009 · 14:06 UTC#4
I use Ulead Photoimpact.....but you can use any image editor....
GUGA
