jsb123 said:
Ducatiboy,
Just so I'm clear, to invest the $50, I would get this:
1. Ability to change the splash/boot up screen, and each time I wanted to change the bootup screen, I would need to take the HD out and change the file name of the bootup screen using a PC?
Yes
jsb123 said:
2. How many background files total can be stored to allow for changing at any time without the CD?
I'm not sure of the exact number, but it's not 1000, it's more like 30. But I never counted the exact number, it might be 20 or 22 or something like that.
jsb123 said:
3. Relating to question 1 above, is it fairly safe to remove and re-install the Z1's hard drive multiple times for changing/adding bootup screen files and background files via a PC? Would you limit the number of time of removal/re-install on your $2K Z1?
TIA,
JSB
I suppose it's safe. There is a possibility that you can drop the drive on to the screen and scratch it or something. And there will be a insertion rating on that connector for how many time you can remove it and reinsert it without the connector failing but I don't know what that is. Without reading the specs on the actual connector they used, I would assume 100+ would be safe. I would guess that 1000+ would be safe. I would think that 10,000 would not be. But where the line is drawn, I don't know.
