I have added a return home button to my screen which has the the following code as the onrelease:
run sc_btnAMM_ReturnHome_OnRelease
I have also (by using the thread below) done a mod to remove the route info data when not navigating.
http://www.avic411.com/forum/viewtopic.php?t=21865
My return home button seems to be working except for one weird thing. When I press it and the route gets set my route info data is blank, now if I go through menu > destination > return home the data is there so it appears that there is a difference between what my button runs when pressed and what is run when the option from the menu is pressed.
Can anyone point me the in the right direction, I've looked but can't seem to find the return home menu option to see what it runs.
Matt.
