GPS antenna location?
By jin22gt · Mar 04, 2009in General💬 27 posts👁️ 5,007 views
Page 1 of 2
Posted Mar 04, 2009 · 23:29 UTC#1
Hello.
Im going to install my F90bt soon! Just got a question about the gps location.
- Im thinking about putting the gps antenna on the rear deck but I have 20% tints. Would the tints interfere with the GPS antenna?
- Can i put the antenna on the front dash passenger corner? would this work? I do have a V1 radar, would this affect the gps antenna?
thanks guys?
Posted Mar 05, 2009 · 00:54 UTC#2
I have mine on my dash, on the drivers side way in the corner, its not even really noticeable, and works fine.
Depending on what brand of tint you have, it CAN interfere with the signal. I would recommend putting it up front, away from it, but if you know what brand of tint you have you may be able to google it and find out if there is interference. (for example, formula One Pinnacle films will not interfere, but others will)
Posted Mar 05, 2009 · 02:19 UTC#3
Mines on the forward dash front passenger side under windshield, works great.
Posted Mar 05, 2009 · 06:07 UTC#4
I guess im going to put the gps antenna on the front dash corner. dont want to risk losing any signal.
Posted Mar 05, 2009 · 06:29 UTC#5
I have my GPS antena in the rear left and I have 20% tint dont know what brand thogh. Works great cant complain.
Posted Mar 05, 2009 · 06:46 UTC#6
i have mine mounted in the left rear corner of my interior and i have 15% tint and it does not affect it at all.
Posted Mar 05, 2009 · 10:08 UTC#7
you could always do a dry test once the unit gets there too. check for signal in the back where you want it before its fully installed
Posted Mar 05, 2009 · 13:17 UTC#8
Mine is in the glovebox and gets very good signal.
Posted Mar 05, 2009 · 13:28 UTC#9
In the wife's Santa Fe its up on the dashboard right corner with her Sirius gps. In our Altima both are on the ledge by the third tail light behind the right passenger seat. Both are working fine.
Posted Mar 05, 2009 · 16:55 UTC#10
i have mine stuck right on the top of the head unit under the dashboard(there is no metal above the radio, just plastic vents) and it has great reception, and no one can see it and ask, "what the hell is that on your dash?"
Posted Mar 05, 2009 · 17:41 UTC#11
I have mine hidden in the top right corner of my car behind my header panel and signal works fine.
Posted Mar 07, 2009 · 03:46 UTC#12
I had my F90BT professionally installed and they said they mount the gps antenna inside of the dashboard and it works just fine.
They are correct I have had no reception issues and the antenna is hidden inside out of site.
Posted Mar 07, 2009 · 06:06 UTC#13
I installed mine inside my dashboard on the supplied metal plate. Works fine.
Posted Mar 07, 2009 · 15:52 UTC#14
I put mine under the plastic cowl between the windshield and the hood. Its invisible and gets great reception.
Posted Mar 07, 2009 · 17:55 UTC#15
I have installed many antennas, both sat radio and GPS inside of the dashboard, generally on the metal plate...no complaints yet!
Luke
Posted Mar 07, 2009 · 23:41 UTC#16
Thats what I did with mine in my Scion. I mounted it on the metal plate under the dash behind the gauge cluster.
Posted Mar 11, 2009 · 19:24 UTC#17
I put mine right on top of the head unit under the heat vents inside the console. It works just fine.
Posted Mar 13, 2009 · 00:27 UTC#18
Put mine right on top of the car on the rear.
Posted Mar 13, 2009 · 19:28 UTC#19
Like others, mine's hidden in the dash, on top of the center HVAC ducts. Every now and then I check the reception, and I regularly get nine satellites showing up as green (i.e. usable signal). I'm pretty sure that's way more than the system needs for accurate navigation.
Posted Mar 16, 2009 · 03:50 UTC#20
i put mine in the front of the dash as close as i could get it to the windshield on the drivers side.....and i havent had any problems yet at all
Posted Mar 16, 2009 · 05:20 UTC#21
Tint will only affect the gps signal it it is metallic. I usually install them on the front dash or under a plastic panel in the front. On my personal vehicle I ran it up to the top of the windshiled and double sided taped it the the windshield in the middle(just above the rearview mirror). This way there is nothing on top of my dash and you doent even notice its there, looks like a factory item. Works great with perfect signal.
Posted Mar 18, 2009 · 09:27 UTC#22
Hey guys, THANKS for all your replys!
Im trying to make the gps antenna discreet as possible. I was thinking about putting the antenna under the front windshield vents, but im scared I will lose reception.
Im not sure if my 20% rear windshield tints are metallic or not. Is there a way to find out if my tints are metallic or not? Im going to try to stop by the tint shop if there isn't a way to find out myself.
Thanks for your help guys.
Posted Mar 18, 2009 · 09:32 UTC#23
how about switching your unit on with the antenna under the dash and see what happens :roll:
Posted Mar 22, 2009 · 03:42 UTC#24
Is the antenna pad really needed? I didn't use the pad. Seems to get ok reception.
Posted Mar 22, 2009 · 03:43 UTC#25
I have mine installed on the top of the unit. I get max signal.
Page 1 of 2
