Phone Book edit software
By darkzide · Mar 09, 2009in Hacks/Mods💬 65 posts👁️ 21,679 views
Page 2 of 3
Posted Apr 16, 2009 · 16:00 UTC#26
Is there a way to load the modified data back into the unit WITHOUT having to get into testmode?
Thanx,
Bud
Posted Apr 16, 2009 · 19:14 UTC#27
Is it possible to get this in a standalone file? Sorry to be a pain, but I'm not so cool with an app that I can't save to my desktop and scan for a virus before installing. Also if in a year I want to edit and this post is gone or the link is dead, I can keep a local copy.
Has nothing to do with you or your brother, I'm sure the app is kick-ass, it's just how I try to stay safe with my machines. No offense intended here.
YES!
I'm not worried about the virus because my scanner is constantly scaning incoming connections so it would be detected and stopped right away; but I would like it for the future in case his server is down
Posted Apr 16, 2009 · 23:12 UTC#28
I would like a stand alone also, I am on a mac, (pre intel) and have to run VirtualPC to emulate windows for things like this, and I don't have it set up to connect to the Internet b/c i really dont need to b/c I do all my web stuff in osx.
Posted Apr 17, 2009 · 01:23 UTC#29
I copied the Phonebook I sent to my AVIC-F90BT from my BlackBerry Curve 8310 to an SD Card after booting to Test Mode, copied that file to my PC, and then edited it using the application discussed in this thread. I proceeded to copy the edited file from my PC to an SD Card, booted the AVIC-F90BT into Test Mode, copied the from from SD Card to the AVIC flash drive (to the proper location). While my Contacts are much better organized now, VR does not work with them. When I press MULTI-CONTROL, wait for it to come up, say "Call Mom mobile", the AVIC-F90BT says something along the lines of "There is no phone connected" or "There is no phone available". But I go into the Phone Settings and see that my BlackBerry Curve 8310 is connect to the AVIC-F90BT via Bluetooth. I then go into Contacts, scroll to my Mom's Mobile number which is in the database as Mom mobile, press the icon for that number and it starts dialing. I hang up and press MULTI-CONTROL again, wait for it to come up, and say "Call Mom" only to receive the same response from the AVIC-F90BT..."There is no phone available.". I can receive calls on the AVIC-F90BT using Bluetooth and the reception is perfectly fine. I was able to use VR before I edited the Phonebook database using the application discussed in this topic. What gives?
Posted Apr 17, 2009 · 01:27 UTC#30
did you turn on VR indexing in the system settings? you might need to allow that to run one time to update the VR to the new contacts. then turn it back off after its updated. might help, might not, but hey, what could it hurt to allow it to run one time.
Posted Apr 17, 2009 · 14:08 UTC#31
I just used this program to clean up my phone database for my F90BT and Verizon Blackberry 9530. Everything works great... but I do have a question...
Is there a way to make the Pioneer not attach "...mobile ...home ... work" on the screen and not say "GENERAL" after the name when I call? If I choose "None" in the software, the radio will just show the name I've entered, but read "GENERAL" after each name. For entries like "Krista's House" in the software... When I use conversational commands like "Call Krista's House" It will either say "Calling Krista's House Home" or "Calling Krista's House General" It's either redundant or annoying...
So in other words... are my choices limited to one of the following...?
A) I enter every contact name in the software as I'd say it in conversation (Call: Home... Josh's Cel... Krista's House...) and specify (Home... Mobile... Home) in the software; And the Pioneer will attach "...home ...mobile ...home" to the end of the name on the screen and when it reads back to me "Calling Home Home" "Calling Josh's Cel Mobile" "Calling Krista's House Home" (Redundant)
OR
B) I enter every contact as I'd say it in conversation and use NONE for the type... such that the names show up just as I entered them in the software (Home... Josh's Cel... Krista's House... ) and the VR will read it back to me as "Calling: Home General... Josh's Cel General... Kristas House General" (Annoying)
I just want to see "Krista's House" in my contacts, and to be able to say "Call Krista's House" and it will repeat back to me "Calling Krista's House."
Right now... it says "Krista's House Home" and when I say "Call Krista's House" it echos back "Calling Krista's House Home"
It's kind of stupid... but I assume it's a Pioneer issue... it's obligated to tell me which number it's calling.
Also... is there any way to include pictures for the contacts on the screen? I'm sure we're lucky enough to have different-colored silhouettes of people... but maybe someone out there can develop a mod to do this?
Thanks for listening... and thanks for making this software app!
Posted Apr 18, 2009 · 01:03 UTC#32
I looked in System Settings and didn't see anything about VR indexing. There is a setting for VR Catalog Mode in the AV System Settings menu and that is set to "On". Where is this VR indexing in System Settings?
Posted Apr 18, 2009 · 04:30 UTC#33
thats what i was talking about. well, if thats already on then there goes my idea
Posted Apr 19, 2009 · 08:11 UTC#34
This is a odd question
Im one of the lucky ones that cant transfer my contacts, so im going to try this out but i have 1 question.
Do i have to enter the contacts name extactlly as it is saved in my phone to work or can they be diffrant.
{ex. Mom cell (in phone) Mother (in unit using this applaction) if i do this will it connect correctly still since there the same number?}
Id like to change some names around but dont want to do it twice so was hoping i can just make the changes in this app and not my phone
Posted Apr 20, 2009 · 13:06 UTC#35
You can type in the names however you want in the software. The AVIC unit/software uses the name that you enter to identify what number to dial on your phone... When that number gets dialed on your phone... the phone identifies which contact it is. Try just dialing your mom's number on your phone without using a contact or speed dial... it will tell you that you're connected to your mother because it recognizes the number that was dialed in. When you use the software to define your contacts... the AVIC is essentially dialing the number instead of your finger.
So... the only thing that has to be common to both is the number... which, of course... will be the same (or else you will be calling someone else). For instance, You could have "John Doe" in your phone, and "My Best Friend" in the AVIC unit/software... So when you say "Call My Best Friend" in your car... it will dial the number that you typed in for that contact... and eventually it will identify it as "John Doe" on your phone.
This is inherently why things "just work" when you use this software to do your contacts... Because you're not forcing any weird characters into the AVIC like they might come over from your phone.
EDIT: To answer your other question... You DO NOT have to change anything on your phone to make this work. I didn't, and it works great with my Verizon Storm 9530.
Sound good?
Posted Apr 20, 2009 · 20:41 UTC#36
thanks Dr. Phan
I just went ahead and tried it out. (sorry for wasting your time but when i wrote that post my truck was parked over a mile away from the comp i was on (at a hospital watching over father) and didnt want to walk there get file walk back, enter 1-2 contacts walk back test it then walk back to hospital. It would have been a major issue since i had to sneak in already since "Not visting hours" B.S. so thanks for the info. I should have posted up when i got home that it worked, but id been awake for 50+ hours and i crashed hard and only woke up a few hours ago. Thanks for repleying though hopefully it will help some one else out.
Posted May 12, 2009 · 20:13 UTC#37
Pardon my ignorance, but what format does the software open? I tried .db, .cvs, .txt, etc. What is the "phonebook database" file ext.?
Posted May 12, 2009 · 20:50 UTC#38
You have to get it off of the Pioneer unit. Search the forums for the "test mode files" put them on an SD card, restart the unit, and find the phonebook db file... That's the file that the AVIC db software will open.
Posted May 31, 2009 · 07:58 UTC#39
This sounded great, but when I download and try to open the application it says "There is no default application specified to open the document "AVICPhoneBookEditor.application". Any thoughts, I really need this. Have tried the sql lite with no luck.
You need the latest .net framewoork from Microsoft
http://www.microsoft.com/downloads/details.aspx?familyid=0856eacb-4362-4b0d-8edd-aab15c5e04f5&displaylang=en
Hi there, this app looks great and I would love to try it but when I did this step, my pc still says "Cannot DL the application, missing required files" any ideas?
Posted May 31, 2009 · 17:09 UTC#40
CAUTION: When I downloaded this file, my AVAST antivirus detected it as a Virus. CAUTION
Posted Jun 19, 2009 · 17:01 UTC#41
Is there any OFFICIAL reply about this information ??? By the authors I mean... 8)
Not seeing any reply, worries me a little bit... you know... :lol:
Posted Jun 30, 2009 · 06:51 UTC#42
all,
had much of the same problems you guys were having.
You might want to check out this post: viewtopic.php?f=34&t=25308
weo
Posted Aug 19, 2009 · 17:19 UTC#43
you are da bomb (pardon the slang)..and so is your brother
palm centro and pioneer...not so hot.
but this little piece of magic did it all
thanks
Posted Oct 09, 2009 · 20:49 UTC#44
This is an awesome app... too bad someone from Pioneer wont recognize this and maybe add it into AVICFeeds... Hhhhmmmm whatta concept!!! I like it!! Pssssttttt Pioneerare you reading this? lol
Posted Oct 13, 2009 · 02:48 UTC#45
Thanx,
Bud
No.
Posted Oct 13, 2009 · 02:53 UTC#46
It's not a virus
Posted Nov 13, 2009 · 16:58 UTC#47
How dop you make this work for Vista\Windows 7?
Now that I have a new PC this will no longer work.
Thanx,
Bud
Posted Nov 22, 2009 · 18:09 UTC#48
As I had the some problem on my Win 7 x64 I use this method:
http://avic411.com/forum/viewtopic.php?f=34&t=25308&hilit=phonebook
I updated it a little for french letters and for the method to select only one part of contact according one categorie. You can find my update version with tutorial here :
Export your outlook contact to AVIC- French version + TUTO [For the moment only in french but if you are interested in it I could prepare one in english]
Posted Nov 28, 2009 · 00:06 UTC#49
Thanx,
Bud
I have it running on Vista and Win 7 x64
Posted Nov 28, 2009 · 06:46 UTC#50
69sixpackbee wrote:How dop you make this work for Vista\Windows 7?
Thanx,
Bud
Okay, so what is the secret?
Page 2 of 3
