what do you do after you get past this step? Haven't really looked into it. Do you enter in the "hacks" on the headunit? I read somewhere you just copy over the hacked files. However, I am too dumb to really understand I guess.
You really need to read the FAQ. This has been covered countless times. In case your eyes are playing tricks on you, it's the FIRST topic. Also if your eyes are playing tricks on you you should not even be attempting to get into the files and altering the codes.
I have read this. Countless times actually. However, I still do not know where to go from there. It has steps "dot 1" to "dot 4", which only describe
how to get into testmode. It does not say what do to after that. I don't even know what testmode is. I have a great deal of experience in programming, but not Pioneer headunits, therefore why should I be an expert? I am simply curious as to what to do after entering testmode. Does my SD card need to have the 2.0 version on it? Can i just change coding while in this magic "testmode" without the having firmware file on my SD card? How do I get to the files I need to get to once I am in testmode?
I think some of the more experienced users should be a little more forgiving when they see posts. If every answer could be solved from the FAQ thread, then there would be absolutely no other need for any other thread, and this forum should be locked. Give us newbs a break.
Read this thread which I found while reading the FAQ a few minutes ago.
viewtopic.php?t=17542
Here's a brief summery, but be sure to read the posts in the link for more exact details. Use an empty SD card that's at least 2gb. After you get in you'll need to backup the MyFlashDisk, do not delete it under any circumstances. With that on your SD card you'll exit the program and remove the SD card from the slot and insert on your PC. Open MyFlashDisk and explore the contents, be sure to turn extensions on. Find data.zip and copy that to your PC. For the most part, it's the files in the data.zip that get changed.
Since you know a thing or two about programming you should do pretty good with it.
FYI - I didn't know squat about programming when I started, but was able to get in change a bunch of stuff just by reading threads over and over. I still have tons to learn and I've been in it since mid November. By no means am I an expert, but getting in through testmode was probably the easiest part of all this for me.
Edited to add: Here's a link from the past that's currently a few theards below this. Info for backing up the MyFlashDisk;
viewtopic.php?f=34&t=18068
