Goodby --- hello Kenwood
By 1fastrsx · Mar 11, 2009in General💬 53 posts👁️ 7,943 views
Page 2 of 3
Posted Mar 12, 2009 · 17:57 UTC#26
There are just so many little things that have now added up to me getting something else. Better or worse I just need something different before this deck finds its self being tossed out my window at 80mph.
I'll give you $50 + shipping for it since you're planing on tossing it out the window....
Posted Mar 12, 2009 · 18:07 UTC#27
$60. Do i hear $70? :wink:
Posted Mar 12, 2009 · 18:19 UTC#28
Relating to the hissing issues you guys have, that's not unit's fault. Or at least not if it's a working unit. I have no hiss. It's actually dead silent where my OEM stereo was hissing pretty bad and Audi called that normal.
Also, touchscreen works just fine on mine.
I'm not denying that the unit doesn't have it's faults but seems like a lot of these are issues that are related to how your system is setup and what aftermarket stuff you are using. Can't blame Pioneer for that.
Posted Mar 12, 2009 · 18:32 UTC#29
No it is the head unit... you can hear the hiss more when you select a different source then it quiets down a little. I think because you are listening to the unit un-amplified you can't hear the hiss, also most stock speakers don't have a separate tweeter and crossover for proper sound staging. The very best factory stereo can not compete with after market equipment period. Most manufactures outsource their audio to aftermarket companies like Pioneer, Alpine etc. and what you get is there bottom of the barrel gear. Case in point my Honda Element came with Alpine factory gear but didn't have separates mid's & high's, the cones are made from paper and was grossly under powered and the sub was not tight. Thats one example... I also have 06 SAAB 93 that Pioneer was contracted for the audio and the same issues are found with that setup. Listening to the radio in your car just using the radio to power your sound may not produce the hissing we are getting.
Posted Mar 12, 2009 · 19:26 UTC#30
Well, my car had a higher-end sounв system (Personally I would not call Bose anything higher-end, but Audi does) that has separate tweeters, crossovers, the works... There's no hiss from AVIC here...
Posted Mar 12, 2009 · 19:36 UTC#31
Fair enough... so does my Element it had separates in the front but the mid cone was paper and the crossover was just a couple of caps on the tweeter to block out the mids frequencies. I think the reason you are not getting the hiss is because you have your AVIC hooked up without using the RCA's just speaker wires to your speakers. Like I said before I went to Al & Eds and put in the new unit and it did the same thing, even worst. The gains on the amps are tuned almost all the way down and I still get the hissing.
Posted Mar 12, 2009 · 19:46 UTC#32
FWIW I hear hiss switching from screen to screen (I believe its not isolated to switching between sources) with my 700. Its connected to the factory harness (ground as well, but will change ground to body later) of my 20th AE GTI's factory Monsoon amp/component speakers. I also have Pioneer 920 XM tuner, ground to body, but hiss is still there navigating the menus.
I vaugely remember hearing it as well when I had it hooked up in my living room, to a small bookshelf speaker, and power inverter.
Posted Mar 12, 2009 · 20:00 UTC#33
Rears are amplified. In any case, if there is a hiss when connected to amps and not when wired to speakers directly, I'd think that the noise is being picked up somewhere, not that the deck is putting out noise...
Posted Mar 12, 2009 · 20:06 UTC#34
My F90 makes my elbow hurt, and I know it's the head unit!
Posted Mar 12, 2009 · 20:09 UTC#35
That was my first response as well but since it makes a loader hissing noise when you select/switch sources leads me to believe that it is the head unit. The only time it doesn't make the hissing is when it is on FM or HD Radio. CD's and DVD's are usually excellent in not having hissing because of the digital nature but I get hissing from them as well. Not to be confused with wyne when the engine is revved or excelorated
Posted Mar 12, 2009 · 20:10 UTC#36
it makes my head hurt too. lol
Posted Mar 12, 2009 · 20:13 UTC#37
:shock:
Posted Mar 12, 2009 · 21:04 UTC#38
Hater....... $80
Posted Mar 13, 2009 · 00:36 UTC#39
Well I just adjusted the SLA for each source on my F90BT and it did make a little difference but you can still hear the hissing... but I'll take it, it is a lot better than it was. I guess Pioneer uses the SLA as a gain control, although it is not completely useful +- 4db and even turned down all the way to -4db it still hisses.
Posted Mar 13, 2009 · 13:17 UTC#40
I have the HD tuner hooked up to my F700 and I hear absolutely Zero hiss when listening to the radio. It's as clear as I could ever ask for. When playing my iPod it's just as clear. I don't have any software mods on my unit and I am running it through a 200W Kenwood Amp with Pioneer speakers in the front doors and Kenwood speakers in the rear doors (F150), (got a good deal on the speakers and amp thus the mish mash).
I'm not certain why people are hearing the Hiss in their systems but I'm not experiencing it with mine. Even my phone calls are clear!
Posted Mar 13, 2009 · 14:39 UTC#41
I have my factory Bose amp connected to the RCA outputs of the F90BT and do not have any hiss - in order to connect it that way I soldered RCAs on the factory connector wires. The Bose system is a POS but the point is that I do not have an issue even with a low-end amp.
Some amps have a swtich for high / low level input as well as a gain control which can mess with the sound if not set properly - what type of amps do you have?
My money is that something is wrong with your setup rather than with the AVIC. The only true test would be to put a different head unit in there (not another AVIC) and see if the issue remains.
I'm confident with some simple trouble shooting you can get rid of the hiss and enjoy much better sound. Whereas my navi system does not sound as good as my M3 stereo (with all the speakers and amps replaced with aftermarket), it sound A BILLION times better than the factory head unit - and I still have the crappy bose amps and crappy bose speakers...for now :wink:
Posted Mar 13, 2009 · 16:39 UTC#42
Spta97,
Thanks for your input, I don't know if you read everything I said about this hissing issue I have. But this has done it from day one with the factory setup and without. This is not a amp issue or a bad ground. The head unit hisses no matter what and even more so when or as you change sources... in other words when you are listening to a CD and you select SD it makes a load hiss then quiets down to the level it was hissing before. The only time it does not hiss is when I am in FM and I think that's because Pioneer doesn't allow you adjust the SLA for FM at all. My point is that CD's and DVD's in general are the best sound source and on my F90BT it hisses on that source/s and it shouldn't. Also that fact that it doesn't hiss on FM tells me that it is not the setup rather the head unit. Like I said in the last post adjusting the SLA on each source made difference but it still hisses. Again I want to thank you for your input.
Posted Mar 15, 2009 · 16:19 UTC#43
Spta97,
Forgive me for not being sure as I'm still a newbie with this unit, but is the SLA the same setting that equalizes the volumes of the different sources? I could see the behavior you descibe as the unit tries to bump up the volume not sensing a signal. I had loud distored noise in general before I turned down the beep volume - what is that set to?
That's odd that you would have this problem from day one , again with another AVIC, and yet many people do not have the problem. After reading your post it does seem to point to the head unit.
Posted Mar 15, 2009 · 16:22 UTC#44
I do get a little annoyed by the sluggish response at times of my F90BT...
If you haven't already, try chaning the memory allocation so that more RAM is used for "programs" vs. "storage". I have RAM allocated ~ 90% for programs, ~10% for storage. My 700 shipped with the 2.0 firmware, with RAM allocated at ~ programs ~30%, storage ~70%.
I've noticed about a 75% increase on button reation and screen transition times. Basically the unit is much more responsive switching between screens. Aside from switching to/navigating SD card, it takes a second or less to move between screens.
Thanks Colnago - I will give this a shot when I have some time.
Is there any down side to making these memory allocation changes? It seems that when this unit is modded to make something better, something else gets worse :lol:
Posted Mar 15, 2009 · 21:20 UTC#45
.. You're telling me! Lately my F90BT has been booting up with an active route! I have to go in and delete the route. No, I didn't have an active route the last time I used it. It is just a random glitch I guess.
Posted Mar 16, 2009 · 12:30 UTC#46
This morning I had a route that I do not recall entering in. If this happens again I guess it may be a problem.
What mods do you have? I have the mods that make the clock bigger and add the other stuff to the map screen (current speed, mute voice guidance, etc.) but since I installed them it seems that the unit is not quite what it was. The clock is the only one I really need although I do like the other ones.
Posted Mar 16, 2009 · 15:55 UTC#47
It's ok I have to look it up in the manual myself. SLA, stand for Source Level Adjustment, which is like a gain of sorts on a amp but this is for your source connected to the headunit. I have on all my source the SLA set to -4 db. Which makes it sound better on my system but you will have to play with yours to get the best possible sound in your car.
Posted Mar 16, 2009 · 16:24 UTC#48
I have the software bypass, route stop button added to the map and deleted European maps.. I think that's all.
I'm really happy with it aside from a couple minor annoyances. It is plenty fast for me. I still want to try changing the memory allocation.
Posted Mar 17, 2009 · 16:08 UTC#49
This same thing happens to me! Every few weeks, I leave to work, and the damned thing tells me to make a random turn. I have no idea where its trying to take me, but I have to delete the route that I never entered! My only mod is that I deleted the beep sound files.
Posted Mar 22, 2009 · 00:12 UTC#50
I guess i must be one of the very very few who have little complaint. I have a f500bt , I have a 16 gb sd card and the unit is Not installed in my ford focus 2009. Everything works wonderfull from video to ipod to my lg voyager phone. I am sure the voice command could be much better at times but apart from that no complaints at all. I live in ontario Canada
Page 2 of 3
