Blackberry Bold Voice Dialing
By BBBold · Mar 11, 2009in Hacks/Mods💬 3 posts👁️ 1,007 views
Posted Mar 11, 2009 · 23:24 UTC#1
For any of you who have a Blackberry Bold and can't get the F90BT to recognize voice dialing, I finally (after many trials and tribulations) got my unit to work perfectly....
- Delete all characters from the name and phone numbers ie; +(),/: etc.
- Only use alfa letters and numerics
- Only use 10 numerals for the phone number with no spaces between ie; XXXYYYZZZZ instead of XXX YYY ZZZZ
- Delete all international phone numbers with more than 10 numerals
- Delete all contacts from the phonebook which do not have an associated phone number ie; contacts with only an e-mail address but no phone number
Once completed in the Bold, delete your connection from the F90BT and also your connection to the F90BT from your Bold. Then re-marry you phone to the F90BT and download the new phone book.
You need to be carefull to fully follow the above directions. If you do, it will work like a charm! Just say "Call FirstName LastName" and the unit will respond with all associated phone numbers, asking which one to dial.
Posted Mar 12, 2009 · 00:01 UTC#2
Or you could just edit your PhoneBook.db file and leave all your contacts as is on your phone .
Posted Mar 12, 2009 · 21:00 UTC#3
...and here's the thread on how to do that: http://www.avic411.com/forum/viewtopic. ... sc&start=0
If you have a lot of contacts, this is a much quicker way of getting from point a to point b.
--Mav
