IDT v4.2 on p46, last for 2.0
By ill.die.trying · Mar 12, 2009in Hacks/Mods💬 801 posts👁️ 102,601 views
Page 33 of 33
Posted Sep 01, 2009 · 22:26 UTC#801
I have two questions related to this mod, as I was not able to figure it out:
1. Is there any way to have the car speed displayed when there is a route, the same like when there is no route selected? I know I can use one of those 3 selectable info fields, but that would be too small.
2. Also about speed: is there any way to show the speed limit info from the map, also without using one of those 3 selectable fields? Something like the speed limit in a red circle.
Thank you.
1) you could add this script on your navigatemap_800_480.ui just under the current clocked speed section
2) if you have the setting turned on then they should show up if the map data has the speed limit available
Page 33 of 33
