I finally finished up my tweaks for now, thanks to Maverickster, BorisM, Keeper22, Lilngeer also N-S-E-W for pointing me to some GPS strings... I also used a little from each one with my twist to them. I have added about 13 schemes for fall, winter, spring and summer and some cool night ones as well from my IGO8 collecton. I have modifed my unit for the latest maps, poi, buildings and dem file. I also have the speedcam setup going as well. I have the backup camera, Sirius Sat and also wired for IPOD and external DVD unit. Here are a few shots of the unit.
New release 5/20/09 see below for information -
Screen shots below using the data6.zip file
Ok lets give this a shot. Links are provided below, PLEASE backup what your going to copy before you do anything so you can go back to what you had.
Note: I have this setup using the modified ezrider.exe and the new license file, I have not tested this with the default ezrider.exe or license file and have no clue if it work . I would recommend using the modified ezrider.exe and license file.
Data.zip has the modifications you see in the pictures above. The compass is the cancel route button
The sys.zip has new fonts and new sys.txt file. (both data.zip and files in sys.zip go into main igo folder)
The scheme files have new schemes that I have been using, unrar or unzip what you want into a temp folder and copy to your apl/igo/content/schemes folder/. Pioneer only allows you to have 18 schemes total at one time on the unit. So pick you may have to play around to find the ones you like the most. I'm working on getting sun and moon and clouds to show up as well.
You can also find these mods on my website - http://gpssoftware.us
Updated 5/20/09 - see below for current updated listing
- Release 3/25/09 -
*Quick Launch Nav Menu while not Navigating across the top - Home, Favorites, Search, History and Search POI
*Moved/Cleaned Up Boxes while navigating
*Stop Nav Button added to compass
*Mute Nav Button
*Added GPS status icon to main windows (pressing takes you to GPS status screen)
*Linear Compass (new style - keeper22's)
*Small tweaks throughout for looks
*MPH and elevation when not Navigating
*Street numbers on bottom of screen
*SYS.TXT has a lot of the tweaks from this board
*Allows you to add certain IGO map color schemes
- Update 4/20/09 - "data2.zip"
*Has green background at top of screen
*Turns off Smartzoom on startup
*Speedcam warning box moved to center screen
*Added speed limit to top area next to current speed
*Changed speedcam barking dog warning to siren warning
* Unit is ready for speedcam database files, just add your speedcam.txt file to the speedcam folder and your set
- Update 4/20/09 - "data3.zip"
*Removed all backgrounds at top of screen
- Update 4/23/09 - "data4.zip"
*Layout similar to data3.zip, changes are icon selection is moved to top and
current mph and elev under icons and speed limit under current mph
*In nave mode, time background changes to match top green background
*wife asked I remove siren sound for speedcam, changed to alert tones
*center speedcam warning box rather than offset towards top
- Update 5/20/09 - "data6.zip"
*As you can see some pretty significant changes to the way it looks
*Added Euro style speedcam/redlight warning and speed limit warning (pictures above)
*Moved around current speed and elevation to free up more screen showing.
http://igo8.gpssoftware.us/avic/data2.zip - rename to data.zip put in main igo folder
http://igo8.gpssoftware.us/avic/data3.zip - rename to data.zip put in main igo folder
http://igo8.gpssoftware.us/avic/data4.zip - rename to data.zip put in main igo folder
http://igo8.gpssoftware.us/avic/data6.zip - rename to data.zip put in main igo folder
http://igo8.gpssoftware.us/avic/sys.zip - this unzips to the main igo folder
http://igo8.gpssoftware.us/avic/scheme.zip - collection of map schemes I have tested with unit. They will only work with my data.zip files.
Here is the modified ezrider.exe and the new license file if you want to add newer 8.0 maps, building files, poi and higher resolution dem file for the unit.
http://igo8.gpssoftware.us/avic/newez4avic.zip - hacked ezrider.exe and new license file
