This is a .cab installation file that allows showing Traditional Chinese characters.
very simple to use
just click the file and install.
very simple to use
Am I correct that you need to install this file when in test mode?
yes you do
install this .cab file under the wince mode
can you make one for simplified chinese OR if it's possible one to include both traditional and simplified?
I think both use the mingliu font file but instead of 409, simplified is 804 I looked at the XML file inside the CAB to see if I could change it but I saw the Big5 string and didn't know how to/or if I should change it
I try to install it from test mode, it said .cab is a invalid window ce file. Any one can help?
I tried to install it, and too got the same error.
Maybe try including the Korean font file (gulim.ttc or batang.ttc) that should technically have all the asian fonts (Traditional Chinese, Simplifeid Chinese, Japanese and Korean).
The only problem I can think of is that these font files have a bigger file size.
I got the same error
been looking for this!!any more input in helping people like me out? ![]()
I tried the method in the other post and it works. Here is the link to the post.
http://avic411.com/forum/viewtopic.php?f=34&t=19394&hilit=asian+font
The only comment I have is: after installed the font and changed the registry. Remove SD card, turn power off but DO NOT press the "RESET" pin on the unit. If you press the pin, the font installed will be gone, and you will have to do the whole step over.
