I had a problem with the unit not booting anymore, also testmode did no longer work... So before I return this unit to the dealer I thought I have some fun with it :
I decided to format the flashdisk; using uBoot and then the option Format MBR. I then loaded the wince, again with uBoot. I used the wince files inluded with the 2.0 firmware update.
Next I loaded a SD with the latest firmware update for europe; the firmware is then upgraded (without maps and stuf). I figured it should now be possible to boot using TESTMODE.
This works up until the system report a MapDBInfo problem. It cannot match the device ID with one of the profiles ( I used EW). Here's the thing. The unit ID is now 0x:0000
I have also tried to add the MAP and DATA folder to the Firmware SD, this works; The upgrade tool reports a new DATA and MAP version.
So here is where I am; The unit boots without splash and starts with the display off. When I press Menu, I get the main menu screen, setting works, NAV and Audio not. Also, the system reports I can only use English(US), Spanish and French. This is an EU unit, so where are the EU languages. The unit ID is reset to 0x:0000.
I think the fix is to reset the unit ID somehow... Anyone ?
