2008 Mitsubishi Evo X Install (Lancer/Ralliart/Evo)
By wiretap · May 08, 2009in Vehicle Specific Wiring💬 9 posts👁️ 19,472 views
Posted May 08, 2009 · 01:16 UTC#1
I received my Pioneer AVIC-F700BT today, so finally I could get my radio put in. The full install took me about 3.5 hours, and honestly, it went flawlessly. The Evo is by far the easiest car to work on. There's a ton of room.. and I mean a ton of room (behind the dash, glove box, and places to route cables). Everything snaps apart and back together really easily. I think I only had to use a philips screw driver twice. (for the dash trim piece removal, well, and the radio mounts of course)
Parts:
- Pioneer AVIC F700BT
- Pioneer GEX-P920XM
- Scosche Dash Kit
- 2008+ Mitsubishi Radio Harness
I started in the trunk with installing the XM box to get that out of the way. I found the perfect place for it. :cool:
Used velcro to hold it in place...
Then I ran the power and ground over to the battery. The antenna will go straight up on the rear window deck inside. You'll see a picture of that later.
The IP-bus cable for the XM unit has to be routed to the front of the car. I removed the back seat bottom to make routing the cable easy, as well as removing the floor trim pieces. Now you have access to the whole cable run tray. The little holders just snap open and closed, so it makes cable routing super easy.
From there, the cable gets routed behind the glove box and into the radio area to be plugged in later. I also ran the GPS antenna for the AVIC at the same time to make things easy. I put that on the rear window deck next to the XM receiver.
Removed the factory radio.
Put the factory vents into the Scosche dash kit.
Then I switched gears and felt like running the microphone for the telephone and voice command. I found the perfect spot in the map lights area. It just pops out with no tools required. I routed cable through the headliner and over to the passenger side A-pilar, down behind the rubber stripping, then down behind the glove box and into the radio cavity.
Now all the cables have been routed and they're awaiting install. I took a short break and worked on the wiring harness. Notice I did the video bypass trick by grounding the 'mute' and 'parking brake' wires. You also have to move the mute wire to a different pin on the harness. The tutorial is found here: http://avic411.com/wiki/index.php/Hand_Brake_Bypass
I then went ahead and put the stock brackets onto the AVIC, plugged everything in, screwed the radio in place, and put the Scosche dash kit on. It looks great!
Fitment:
Here's the GPS and XM antennas on the rear window deck. They're coming through the child restraint door. (I removed it)
Put the trunk all back together and put some wire loom on the wires coming from the XM unit.
And in case anyone missed it, here's my glove box mod, which enables USB power for connecting a 2.5'' hard drive to the AVIC unit. Tutorial: viewtopic.php?f=34&t=24072
Finally, it's done! I tested for full functionality, GPS, XM, AM, FM, bluetooth...all working!
I didn't mess around much.. I threw a custom boot screen on it, put the test mode files on a SD card, then booted it into Windows mode to make some backups of the unit's files before I go about modding it. ^_^
Posted May 08, 2009 · 01:32 UTC#2
Absolutely Beautiful!!
Great Job! I really love it.
Posted May 08, 2009 · 03:28 UTC#3
Posted May 27, 2009 · 13:00 UTC#4
how is the bluetooth mike sound? I have a mitsubishi outlander with the same map light fitting i was gonna drill it and pass the mike through but yours looks more stealth.
Posted May 28, 2009 · 02:34 UTC#5
The mic works great. People say they can hear me perfectly, and there's no echo/feedback on their end either.
Posted Aug 17, 2009 · 16:58 UTC#6
Do you have SSS? How did you tie it in with the Rockford Amp? Also do you have the diagram of where you tied in the speed sensor wire or is there one?
Posted Aug 07, 2010 · 13:06 UTC#8
How is your XM reception with the antenna inside the car?
Posted Jun 05, 2011 · 02:57 UTC#9
did you order the stock nav bracket from dealer? im looking to do this.... shop used metra kit and the kit itself holds the nav in and its not mounted with brackets.
