OBDII/Dash/Car stats / possible programs?
By bsnively · May 25, 2009in Hacks/Mods💬 129 posts👁️ 47,511 views
Page 5 of 6
Posted Apr 24, 2010 · 19:14 UTC#101
Hi Guys, I'm Hamish from EvoScan. My WindowsCE 4.2/5.0/PPC/WM5/6/7 (netcf2) software is being extended to cover more screen resolutions and more gauges and more vehicles for datalogging. I'm keen to work with you guys to get it working for the AVIC devices.. This seems like a cool project. Anyone got a spare AVIC device I can borrow to set it all up?
That would be great!!!
Now i hate that i am from Europe so you can`t test it on my device :(
Posted Apr 24, 2010 · 21:29 UTC#102
Well, I wrote the avic-modder that you can use to mod the AVIC's OS, or I can just do any modifications you'd like for you. I also have experience getting another engine management/OBDII logger app running and successfully communicating via the AVIC's usb port. I'll help any way I can. I don't have a unit for you though, sorry. Wife's already mad about how often I have the thing connected to my PC verses being in the car "where it belongs". :)
Posted Apr 24, 2010 · 22:39 UTC#103
How and why do you have your avic hooked up to your PC?
Posted Apr 24, 2010 · 22:52 UTC#104
I develop the software for the avic on my pc and debug via usb on the avic.
Posted Apr 24, 2010 · 23:32 UTC#105
Sorry, I am confused, how do you power the Avic when it is hooked up to your PC? Do you physically move the Avic to your PC or just use an emulator? I tried using emulators, but could not find any that work properly with 3.0
Posted Apr 24, 2010 · 23:51 UTC#106
Physically move it. It came with a ac power adapter. It's a F500, maybe you didn't realize that one. It's not a "mount in the dash" type.
Posted Apr 25, 2010 · 00:44 UTC#107
Damn! that explains it :( , I have a spare F700 that I wish I could hook up to my computer. It would save me countless hours running up and down to my car testing out all these mods that I do.
Posted Apr 25, 2010 · 01:19 UTC#108
Abb, power it with an ATX power supply. That's what I do with my desk F90BT that I use to test hacks before deploying to my car's F90BT. It's really easy to wire the harness up to the +12V and ground off the hard drive Molex connectors, then the handbrake to one of the GND wires. I use a supply with the On/Off switch on the back, so then I can just jumper the Green and Black wires on the 20/24 pin connector and then use the switch to apply/remove power. It's an Antec SU-380, for reference (came with a case I swapped a bigger supply into).
If you need diagrams or pics, let me know.
Posted Apr 25, 2010 · 02:26 UTC#109
I would definately like to see some pics on the wiring. This would be awesome if this works! Please, PM me!
Posted Apr 26, 2010 · 14:38 UTC#110
WOOHOO!!!!! IT WORKS!!!! Thank you FourG, you have no idea how much time this is going to save me! :D:D:D
Posted Apr 26, 2010 · 15:31 UTC#111
No problem. Scarily enough, it looks like we might have the exact same Sammy monitor. :D
My rig:
I've updated the Wiki instructions to add mention that you'll probably want to add a switch on the ACC line so you can emulate the auto environment better (you usually have standby power on +Battery before the ACC gets juice when you turn the key). I still haven't done this on my setup, but I do so at my own (semi-informed) risk.
Posted May 03, 2010 · 05:34 UTC#112
Too bad the AVIC's didn't run Linux, since VW Research released a kernel module that reads and writes CAN information just as you would opening a TCP port and read/write data in C++ ;p
(quick link for anyone who was actually interested by the statement above: http://en.wikipedia.org/wiki/Socketcan)
Posted May 04, 2010 · 02:25 UTC#113
Linux can be run on absolutely anything, im suprised noone has put forth the effort to run it on these.
Posted May 04, 2010 · 12:23 UTC#114
Yes, Linux can be put on it, but, it is a little more complicated than that. First, you would need to set it up so that Linux would be recognized in the bios and be capable of 'boot' so that the OS can be loaded. Second, The AVIC software will not play on Linux, so you would have to redesign the ENTIRE Avic NAV and MAIN software to work on Linux which is a very complicated procedure. Youre welcome to try, but to me, this is a lot of work for very little advantages, and I have used Linux and I am NOT a fan of it.
Posted May 05, 2010 · 06:30 UTC#115
I have used linux and love it! But yeah, not appropriate here.
BTW, you can reach me at [email protected] (really)
Posted Sep 20, 2010 · 03:10 UTC#116
Garmin has a product (cable) that's called "EcoRoute HD" at https://buy.garmin.com/shop/shop.do?pID=38354
It connects to a ODB II port and the other end connects to regular Garmin GPS units to transform them into a full ODB II reader, diagnostic tool, to see all kinds of info plus monitoring fuel consumption.
Just curious if Pioneer will ever come out with a "cable" like Garmin's to enable the readout information to be displayed on screen?
After all, Pioneer even calls that the "Eco" feature with some kind of distance/fuel info, which seems they are keen on implementing features like this.
Posted Sep 20, 2010 · 07:52 UTC#117
The cable is just the means travel the Data to from the source. The Avic would still need to have software installed in the unit. There again, the software has to be WinCE compatible, which the Garmin unit does not have. In other words, it is highly unlikely to have this on our units. It would be nice though!
Posted Sep 20, 2010 · 16:47 UTC#118
what is the likelihood that Pioneer steps up this "eco" feature on the next release cycle on the flagship Z-series?
Just wondering if I have to get the Garmin unit now to get the ODB II data.
Posted Sep 24, 2010 · 20:08 UTC#119
So you have something working :D ? Could you share more information such as which app and cable you are using? Any screen shots? Do you have to boot in CE mode, or could you have a shortcut from the AVIC GUI?
Posted Sep 28, 2010 · 17:34 UTC#120
Any new info on this? Just bought an X920BT and would love some sort of OBDII stats on the screen. They make a program for the Android phones but im assuming this wouldnt show up on the Pioneer screen:
http://torque-bhp.com/
Posted Nov 06, 2010 · 22:21 UTC#121
So, i am just wondering if it is possible to put bluetooh sd card to our units and install some program via usb like it has already been done with wifi sd card?
Posted Nov 20, 2010 · 06:55 UTC#122
Anyone care to talk about the new mod that Russian guy made with the OBDII software integrated?
Posted Dec 04, 2010 · 01:14 UTC#123
The reaction time on the F90BT between touchscreen inputs is so slow, I can't imagine how well it would work for using OBDII software. I use an app called Torque on my Android phone, and then purchased a $20 OBDII reader via eBay...works like a champ and I can easily take it w/ me to test on other vehicles as well. Honestly, trying to incorporate this into the decks OS is more trouble than what it's worth.
Once the devs over on the Android forums get TV-Out working on my Samsung Epic, I'll be able to use the front A/V input and have it show everything that is on the phones screen from OBDII software, to GPS (which I used 10x more than the AVIC's GPS), videos (since the F90 doesn't like movies via SD), streaming music, etc.
Edited Dec 04, 2010 by m5james
Posted Dec 28, 2010 · 03:33 UTC#124
]I used my Ipod touch with DashCommand Software and the iPod app TvOut2... also have an innovate OT-2 wireless OBDII reader.
Video Mp4 attached.
Edited Dec 28, 2010 by gibear2k5
Posted Mar 28, 2011 · 00:13 UTC#125
How about this.. .Softiny OBD-Board
or
Edited Mar 28, 2011 by gibear2k5
Page 5 of 6
